cj-3a rear axle shaft upgrades (1 piece?) - JeepForum.com
post #1 of 7 Old 10-19-2011, 07:38 PM Thread Starter
98blacksahara
1951 CJ3A
hello,
I have a 1951 cj-3a that I will be building for moderate trail use. I would like to keep the factory D44 housing, but upgrade rear shafts to something with a better spline count and a new carrier.
I plan on lockers and 33's and some pretty decent wheeling.
I am putting a scout 44 with disc brakes up front. I will be keeping the little flathead for now, I have always had a soft spot for the little guys.
If someone could point me in the right direction, that'd be great
Originally Posted by RubiconRazorbac View Post
Well, I've never eaten a turd sandwich, but I wouldn't have a problem recommending not to try it.:thumbsup:
But I'm sure someone out there will post that they regularly eat turd sandwiches with no problems...
98blacksahara is offline
post #2 of 7 Old 10-19-2011, 07:53 PM
brownbagg
1930 MK Compass
dana 44 out of a postal jeep, heavy duty, same size and some have lockers
brownbagg is offline
post #3 of 7 Old 10-19-2011, 07:56 PM Thread Starter
98blacksahara
1951 CJ3A
Any place you know of sell just the shafts. I have the carrier and whatnot. Just looking for shafts for my freshly prepped housing
post #4 of 7 Old 10-19-2011, 08:04 PM
Stephen_P
herm the overdrive guy sells a full floating kit for the 44. You can buy just hte shafts or all the parts needed for the conversion.
That is probably the best or easiest option for that axle. I think you can also find some companies that will cut custom shafts but you will still probably need to go to a full floating axle.
I don't know of anyone that stills makes or sells a one piece axle upgrade for that offset dana 44.
Stephen_P is offline
post #5 of 7 Old 10-19-2011, 08:56 PM
chromegrille
1947 CJ2A
1 piece shafts will never work in the 2 piece housing.
Either full float what you have, or look for the CJ 70-71 D44 1 piece axle assy.
The postals are centered pumpkin, and are not offset for the D18 transfer case.
but...it's your Jeep
chromegrille is offline
post #6 of 7 Old 10-20-2011, 05:15 AM Thread Starter
98blacksahara
1951 CJ3A
Just looked up herms kit. Seems like the way to go
post #7 of 7 Old 10-20-2011, 10:16 AM
colojeepguy
1970 CJ5
The 70-71 CJ axle would be the way to go...if you can find one.
Dana 44 with a bigger housing and 1 piece 30 spline axles.
colojeepguy is offline
End play on 1 piece Model 20 axle shaft Boomer Jeep CJ Forum 1 02-25-2010 07:26 PM
Model 20 rear axle one piece question garbageman Jeep CJ Forum 18 12-01-2009 09:29 PM
2 piece to 1 piece AMC20 axle swap question Robb Kiker Jeep CJ Forum 11 11-17-2009 08:01 PM
Rear right axle came out of shaft. builtup304 Jeep CJ Forum 6 09-08-2009 12:11 PM
axle shaft vs. rear-end bcar240 Jeep CJ Forum 4 09-02-2006 07:56 PM
