CJ -360 problems - JeepForum.com
post #1 of 4 Old 12-16-2003, 03:36 PM Thread Starter
smokinstang70
Angry CJ -360 problems
Hey Guys...newbee here... I just bought a 78 CJ7, 4in suspension lift, 3 in body, 35 in BFG Mud terrrains, and an AMC 360 with side exhaust. I love the jeep, but I can't get it running right. I have worked on cars all my life, but this one is kicking my butt. I have set the timing 8 degrees advanced, I have rebuilt the holley 600 vac sec. and I have replace the cap, rotor, plugs and wires, but It still won't run right. It smells like raw gas coming out of the exhaust. I have adjusted the carb, but with little to no effect. I have headers on it and had an exhaust leak about a month ago, but I fixed it. Any ideas?????? thanks in advanced.
Also I am looking for several used parts. If you have anything to sell or know where I can post a classified, please let me know.
Walter - walter.dumas@gulfaero.com
smokinstang70 is offline
post #2 of 4 Old 12-16-2003, 03:55 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Insure the firing order is correct. Stuck or mis-adjusted float, missing or bad power valve,missing jet(s),wrong gasket(s),mis-adjusted choke,excessive fuel pump pressure. Try swaping carbs to see if the problem goes away.
jeepdaddy2000 is offline
post #3 of 4 Old 12-16-2003, 09:53 PM
Crash&Burn
First thing I'd try a different carb........
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #4 of 4 Old 12-22-2003, 02:16 PM
redhat6161
i'm curious, what type of ignition system do you have on there? i put an HEI unit on my 360 and couldn't be happier... this was after i had the prestolite ignition previously, this is a notoriously bad unit. good luck with it.
redhat6161 is offline
Still Looking 4 Help On Oil Problems hostileConCepts Jeep CJ Forum 2 05-13-2009 04:21 PM
Still Looking 4 Help On Oil Problems hostileConCepts Jeep CJ Forum 0 05-12-2009 10:23 AM
CJ Problems devil dog 85 Jeep CJ Forum 8 05-17-2007 12:09 AM
having problems?? muddin84cj7 Jeep CJ Forum 2 10-20-2003 01:26 PM
2 problems MudMonster Jeep CJ Forum 7 05-11-2003 10:42 PM
