Chrysler 9.25 axle - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Chrysler 9.25 axle
Bds fox ipf 2.0 racing series shocks now available at rockRubicon express discounts from oconee off-roadRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 09-07-2014, 09:04 PM   #1
mattp1788
Chrysler 9.25 axle
Have a Chrysler 9.25 rear axle that was given to me but it needs new gears and bearings in it. What's everyone's opinion on this axle under a cj7? I have the narrow track axles under it now and I am looking for a wider stand and beefed up axles but on the cheap side... Do y'all think this axle is worth it or should I find something else to put under my jeep?
mattp1788 is offline   Reply With Quote
Unread 09-07-2014, 10:15 PM   #2
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
Is it out of a Dakota or Durango? If so The 6x4.5 bolt pattern is an odd ball pattern and I don't think there is a lot of aftermarket support for it. Not would it be easy to make the front axle match that pattern. Regardless, it sounds like it needs a fair bit of work and money put into it if you don't have the knowledge and/or tools to set up the gears properly. If it were me I would pass and find a more common axle that requires less work.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote
Unread 09-08-2014, 06:14 AM   #3
jp360cj
1977 CJ7
Something that needs gears/bearings won't be cheap, unless you can do all the work yourself. Even then it could go either way
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote
Unread 09-08-2014, 06:53 AM   #4
mattp1788
The axle is out of a durango!
Unread 09-08-2014, 07:01 AM   #5
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You are usually looking at $1000.00++ to put new gears and bearings in it and then you have to try to find rims to fit on it as the bolt pattern for the rims is an odd ball.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 09-08-2014, 02:41 PM   #6
Jim1611
Jim1611's Avatar
Stay away from it! I have one in my pickup and am not at all impressed. You can't buy a decent aftermarket locker for them, mine anyway and they use oddball gear ratios. You'd be better off getting a Dana 44 and putting the money into it.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote
