Choke Problem!!! - JeepForum.com
post #1 of 3 Old 05-23-2007, 07:09 PM Thread Starter
Natto
Choke Problem!!!
Went off into some mud yesterday and now my choke doesnt work.......just stays open which causes it to die unless i constantly give it gas........tried just spraying some carb & choke cleaner figured it was gummed up a little bit but it still refuses to move. any ideas?
86 CJ7 Renegade (Under Construction!)
258 Jasper Straight 6, D-44 & D-30, D-300 Xfer, T4
31x12.50x15 Thornbirds
3 1/2"x1/4" Round Steel Bumper
Natto is offline
post #2 of 3 Old 05-24-2007, 12:26 AM
kavephish
1981 CJ5
does it move by hand, or is it still locked solid after you tried the lube? - someting's bent/binding - Is it electric? - check for power to the red wire. Is it vacuum actuated? did you check the vac lines?
kavephish is offline
post #3 of 3 Old 05-24-2007, 05:55 AM Thread Starter
Natto
it will move by hand, which makes me think it might be electrical, and the previous owner "removed" all the vacuum lines and it's been running fine without them and since i never got a chance to see it with the hoses hooked up so i have no idea where they go ill check the power to the red wire everything got covered in mud/water and my electrical wasnt the best to begin with......... thanks for the advice
Natto is offline
electric choke vs. manual choke... hex Jeep CJ Forum 12 08-18-2013 08:29 PM
Carter BBD Carb.-Choke Problem! PICS Rocket6R Jeep CJ Forum 21 06-14-2013 01:05 PM
Choke problem bkeast17 Jeep CJ Forum 3 03-25-2006 06:57 PM
Electric Choke problem..help! sierra1boy Jeep CJ Forum 13 01-20-2006 03:35 AM
Choke Adjustment/Problem californiacj Jeep CJ Forum 0 10-15-2004 10:09 AM
