Choke problem - JeepForum.com
post #1 of 5 Old 04-03-2012, 10:24 AM Thread Starter
yetiwarrior82
Choke problem
ok i've worked on my 79 cj7 all morning and finally have it running but problem is it doesn't stay running and i have a feeling its because of the electric choke. let me know what you think of the pics and if you can help me out let me know please and thank you.
yetiwarrior82 is offline
post #2 of 5 Old 04-03-2012, 11:09 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Is there juice to the choke wire with the ignition on?
When you pump the throttle before starting cold, does the choke close the butterflies?
Does the choke open the butterflies as it warms?
Is the Choke Pull-off set properly?
How fast is your fast idle speed in RPMs?
What are your fuel mixture screws set at?
What are the symptoms when it dies? Is it just a slow sluggish idle that eventually stalls out? Or does it shut down suddenly from a strong idle?
Have you checked for vacuum leaks? From what I've seen of your engine, and the POs hacks, I would be shocked if you don't have leaks.
Matt
Matt1981CJ7 is offline
post #3 of 5 Old 04-03-2012, 11:32 AM Thread Starter
yetiwarrior82
i have no juice going to it. and i have to move the choke by hand. like it just doesn't work.
post #4 of 5 Old 04-03-2012, 12:29 PM
CJ7Sasquatch
1979 CJ7
Dosent look line it's hooked up right, it needs a ground to the carb from relay a did you have no juice jump a wire from the pos terminal to make it works altogether, if it does you need to check for a switched hot, there should be a bigger switched hot sone where on the drivers side fire wall that you can tap off of
ECV 1864
CJ7Sasquatch is offline
post #5 of 5 Old 04-03-2012, 01:11 PM Thread Starter
yetiwarrior82
i'm just trying to figure where the red goes
carb , wire
Electric choke wire problem SOreCJ7 Jeep CJ Forum 0 09-22-2011 12:47 PM
Choke Problem!!! Natto Jeep CJ Forum 2 05-24-2007 05:55 AM
Choke problem bkeast17 Jeep CJ Forum 3 03-25-2006 06:57 PM
Electric Choke problem..help! sierra1boy Jeep CJ Forum 13 01-20-2006 03:35 AM
Choke Adjustment/Problem californiacj Jeep CJ Forum 0 10-15-2004 10:09 AM
