A Childhood Memory - Page 3 - JeepForum.com
post #31 of 41 Old 02-03-2013, 10:42 AM
richardg412
Originally Posted by auburnhunter View Post
Can you please tell me what type of camera or setting you used to take those pictures. They are great.
hey auburn i use a nikon d7000 my iso was set around 400 and i was using my nikkor 25mm prime in manual, if you want to take a look at my photography http://www.flickr.com/photos/richardg412/ thats for my digital stuff i occasional do although i prefer film, i'll do my best to get pictures of the build for a friend
richardg412 is offline
post #32 of 41 Old 02-05-2013, 11:50 AM Thread Starter
Hbryant123
1979 CJ7
Just and update for everyone, the jeep is now in my garage! I have begun trying to find out why it is not getting any apark.
Hbryant123 is offline
post #33 of 41 Old 02-05-2013, 10:23 PM Thread Starter
Hbryant123
1979 CJ7
So i have gotten the motor to run and it has tons of blowby and was making a slight ticking sound. Since the engine is old and has been used alot i am going to rebuild it. Whats everyones thoughts on this?
post #34 of 41 Old 02-05-2013, 10:55 PM
86cj74.2L
86cj74.2L's Avatar
I am very happy with the rebuild in the 86. I'm sure there will be some here telling you now is your chance to go V8.
86cj74.2L is offline
post #35 of 41 Old 02-05-2013, 11:09 PM
CrankyD
1983 CJ7
My thoughts are, get some kind of brakes on it and take it for a parade lap around the neighborhood!!!
CrankyD is offline
post #36 of 41 Old 02-06-2013, 10:23 AM Thread Starter
Hbryant123
1979 CJ7
Haha the fluid resivor was actually full along with the radiator. haha i may take it for a spind
post #37 of 41 Old 02-06-2013, 12:19 PM Thread Starter
Hbryant123
1979 CJ7
It is already a v8! Some say swap in a 360, but i found a rering kit for about 300$.
post #38 of 41 Old 02-08-2013, 04:07 AM
86cj74.2L
86cj74.2L's Avatar
If there's no ridge you may get by. I'd at least run a 320 grit ball hone through the bores for the rings to seat.
Sometimes the ring packs will tell you what the recommended grit hone to use for their rings.
post #39 of 41 Old 02-08-2013, 12:07 PM Thread Starter
Hbryant123
1979 CJ7
Yea i have one that i can use, ive had succes on using it on small engines. This is my first v8 rebuild. Anything else i should know
post #40 of 41 Old 02-08-2013, 01:07 PM
86cj74.2L
86cj74.2L's Avatar
Of there is a ridge you can feel with your fingernail get rid of it with a ridge reamer before you push the pistons out if you plan on reusing them.
I've not done a AMC V8 but it seems the oil pump clearance is important. Find JeepHammers write up on it. There are plenty here to guide you In a V8 build. Look at Matt's it's got everything.
Replace the CAM bearings. You'd be surprised at how much pressure is lost through them worn bearings when you put new ones on the crank and rods.
post #41 of 41 Old 02-12-2013, 01:14 PM Thread Starter
Hbryant123
1979 CJ7
My plan is to replace the oil pump because it comes in the kit.
