Chieftian Turn Signal wiring help..
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
I am hoping someone can provide me with the information I need to wire in an aftermarket turn signal flasher switch I am trying to put on my ’64 CJ5A. It says “Chieftain” on the chrome plated switch housing. It is designed to attach to a steering column by means of a hose clamp type of mounting. It has a pull-out hazard warning switch below the stalk. On the wiring pigtail there are SEVEN colored wires on the original, someone put a second pig tail on it changing the colors
but it looks like it was done for a reason..went from seven wire to 6 wire...so cracking either set of color codes should tell me what wire goes where... Original mfg wires color changed pig tail ( to 6 wire Grey /Black strip changed to White BLACK changed to Green RED changed to Blue Yellow changed to Purple Blue together with Yellow(Purple) Grey Changed to Yellow Green Changed to Grey I need to know which wires go where. Any help you can give is greatly appreciated. I tried looking on the web but my search was futile. Thanks in advance. doctordave
#2 |
I'd head on over to http://www.earlycj5.com/forums/.
If you do a search there, you'll find lots of info on your question. I went bug nut trying to get all my lights/signals to work properly, and these guys had the info, many threads of info. |
#3 |
Most after market turn signal systems were really semi truck add ons. You might try your local truck stop. Most will have a comparable unit on the shelf with a wiring diagram on back. Otherwise you can crack open the case and identify the wires manually.
#4 |
SERVANT TO THE JEEP GODS
As mentioned above, most of those are rig parts. Mine is as well and let me tell you, it was a real PITA to get wired correctly! I can have a look and snap some pics for you but it won't be for another week when I get home on days off.
'84 CJ-7: 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, Yukon 1 pc axles, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rear aussie locker, twin sticks/clocking ring waiting to go in. The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied. <------------and yes, that is her. :-D |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
