Chevy Heater Blower Motor - Page 5 - JeepForum.com
post #61 of 63 Old 02-10-2011, 02:52 PM
turbogus
1978 CJ5
Update: Got the brass/copper heater core and looking it over I found that the reason my old core had sprung a steam leak is that the top bracket that's brazed to the core had broken loose, this allowed the core to move around where the top tank (firewall side) had abraded against the heater box enclosure. Looking at the new core and the brazing looks better'n the old one. Glad the local shop chief was able to find one of these, he like myslef are disdianful of aluminum radiators and thier inherent fragility not only from physical damage but from electrolysis of the coolant over time. For as long as I can find them, I'm sticking with the 'old school' brass copper radiator and heater cores.
Also when lubing the internal cable I noticed how the cable end was secured with a 'push nut' after I reassemble the box into the Jeep going to get some and secure those slipping cable ends once and for all.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #62 of 63 Old 03-29-2011, 11:11 AM
Clemmohb
This is a pretty easy one person job EXCEPT for when you re-install the heater/ventilation system. That's when you need somebody guiding you from the engine side so you can stab everything back where it needs to be. As soon as you have it lined up, silicon the heck out of the opening and draw it up tight. Some posts have said the hole needs to be enlarged about 1/4". I had to go at least 1/2" and I had to take out the hole that the plug fits through (just ground it bigger). You have plenty of motor flange to work with, so don't worry too much. Did mine on a 86 CJ-7 with the 4-banger. Screws are in the same place as on the six. The one hidden behind the engine is kind of hard to see, and it hides under a vacuum manifold on my unit. Two screws held the manifold and it was easy to remove. Removing the battery tray makes the whole process simpler as well. Took out the passenger seat (4 screws/bolts) and that gave me plenty of room to work inside without removal of the dash or anything. This would be a really good time to replace the Defroster duct hose! Mine had turned into confetti, but its over 25 years old.
Last edited by Clemmohb; 03-29-2011 at 11:12 AM. Reason: wrong year model referenced!
Clemmohb is offline
post #63 of 63 Old 12-30-2012, 02:26 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
Just my .02
I just finished installing the upgrade, I went with the PM102 (China) and an autozone heater core. The diameter of the pm102 was larger, no doubt. I figured that in itself was enough for me because my blower motor on high is about as crappy a you could get. I used an air saw and cut out 1/4 in all the way around the opening, then stretched the original foam seal around the new motor.
It certainly moves more air than I thought possible!! I just drove around and was plenty comfortable on speed selection 2..up all the way it sounds like a 747, so unless I need to really defrost the heck outta something #2 is fine!
I would recommend this upgrade for sure, and to add to the posts in here, there are a total of 4 bolts (nuts) you have to get from the firewall on the engine side. and when you cut the new hole, make sure to cut a little extra up and towards the passenger side, the bolt restricted me from going in and the sleeve on the motor wouldn't let the unit come up...A perfect catch 22! I was able to pry the motor out a little using the sleeve, and pushed the unit up at the same time. It "popped" into place and held just fine, however if I was going to do it again, I would have trimmed that up so I wouldn't have to be a contortionist next time!!!
All and all, I love it. Chinese crap and all, it works for me.
Thanks again to all the contributors to this thread, I swear I have saved more than my membership could have ever cost!!!
Tom
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
Heater Blower motor upgrade napoleoneight Jeep CJ Forum 84 01-10-2015 04:12 PM
Heater blower motor dustbag Jeep CJ Forum 15 10-17-2009 07:11 AM
Did heater core, and blower motor upgrade, no fan now. Blthomas Jeep CJ Forum 13 02-13-2009 03:00 AM
Removing heater blower motor? mmerlina Jeep CJ Forum 13 03-26-2008 08:57 AM
question (another) on chevy blower motor update Kingair Pilot Jeep CJ Forum 6 03-16-2008 11:07 AM
