Chevy Heater Blower Motor - Page 2 - JeepForum.com
post #16 of 63 Old 07-17-2006, 03:35 PM
Geer_hed
Geer_hed's Avatar
Originally Posted by jeepwhore
Does anyone have any pics of the cable routing?
Yes. J Strenks:
From a CJoffroad thread....
Originally Posted by weprint
The Chevy blower motor has a cooling vent hole for the motor while the Jeep motor does not. I assume you must seal this hole to keep water and debris out. Does this cause any problem with the life of the motor?
Depends on what kind of environment the motor is likely to see most. Moisture and heat are both enemies of the blower motor. I would seal it up and not use it excessively, IMHO... the reman fan comes with a plug for the hole if you want to use it.
85 CJ7 / 258 / T176 / Dana 30/ AMC 20
Geer_hed is offline
post #17 of 63 Old 07-17-2006, 04:37 PM Thread Starter
MuddyMules
MuddyMules's Avatar
Delete
MuddyMules is offline
post #18 of 63 Old 07-17-2006, 05:07 PM
jeepwhore
I asked in another thread as well but....what about a close up of the linkage/pivot on the "heat" cable. Mine seems to be missing whatever it is that bolts to the end of the heater box and blocks off the opening and attaches the linkage.
jeepwhore is offline
post #19 of 63 Old 07-17-2006, 05:50 PM Thread Starter
MuddyMules
MuddyMules's Avatar
Delete
post #20 of 63 Old 07-17-2006, 06:12 PM
jeepwhore
Its the one in the second pic (in the background by that nice purple box ) Can you get me a shot of it more from the drivers side (but just as close up) I need to see it from the end of the heater instead of the front
post #21 of 63 Old 07-17-2006, 06:26 PM Thread Starter
MuddyMules
MuddyMules's Avatar
Delete
post #22 of 63 Old 07-17-2006, 06:40 PM
jeepwhore
Awesome, thanks for the pics. I know I've seen that part somewhere in my pile of junk but I have a sneaking suspicion I threw it out last weekend.....go figure.
post #23 of 63 Old 07-17-2006, 06:44 PM Thread Starter
MuddyMules
MuddyMules's Avatar
Delete
post #24 of 63 Old 07-17-2006, 07:38 PM
dave_dj1
thanks all, i guess i'll have to do mine one of these days
dave_dj1 is offline
post #25 of 63 Old 08-06-2006, 03:43 PM
tomthbomb
CJ7 1/2 Top Club mem. #1
tomthbomb's Avatar
1978 CJ7
Mine is in.
All I can say is keep your floorboards free of leaves and sand!
Turn this badboy on and it's like running down the road 90mph with the top off!!
1978 CJ-7 original owner; AMC 401 V-8 (w/some goodies);NP4500;D300 (w/Curry 4:1); D44 front;AMC20 (Warn one piece axles) rear
tomthbomb is offline
post #26 of 63 Old 08-06-2006, 04:16 PM
John Strenk
John Strenk's Avatar
1976 CJ5
That top bolt is special also. It has a collar on it so you can tighten it up and still allow the lever to move.
You throw things out? Wow.
Also you might want to inspect your heater box for leaks. I added a bunch of extra screws to keep it tight.
John Strenk is offline
post #27 of 63 Old 08-06-2006, 06:59 PM
Shameless Elmer
83 CJ5
1983 CJ5
Good to see you back on the forum CJ_Fan. How's the family doing?
but more important than broken Jeeps.
Shameless Elmer is offline
post #28 of 63 Old 08-06-2006, 07:01 PM
fyr196
fyr196's Avatar
I looked around and I see my blower motor is right behind the glove box. I think I read that the 1977 and before had this. Is there any upgrade for this and would anyone know why is my 1980 like this? 1980 CJ7 it has fiberglass everything, but the windshield frame. It was rebuilt by a PO. Can I just buy everything to replace this and make it work, or does the fiberglass tub prevent this?
fyr196 is offline
post #29 of 63 Old 12-19-2008, 03:53 PM
USMC_0369
Hi guys...found this forum by searching around for this very subject. Glad to see the specs for the vent routing in this one. I ripped the cable system out of the YJ after the dash controls broke apart. I'm hoping to perma-fix it to split the air between the floor and window vents, and bring in 50-50 fresh air to keep the window fog down.
Also, bumped because of the crazy winter we're having here in the desert, maybe others could benefit.
USMC_0369 is offline
post #30 of 63 Old 01-06-2009, 09:11 PM
wetracer
1978 CJ5
Great thread. Will this chevy blower work in a CJ5 also?? Mike
wetracer is offline
Heater Blower motor upgrade napoleoneight Jeep CJ Forum 84 01-10-2015 04:12 PM
Heater blower motor dustbag Jeep CJ Forum 15 10-17-2009 07:11 AM
Did heater core, and blower motor upgrade, no fan now. Blthomas Jeep CJ Forum 13 02-13-2009 03:00 AM
Removing heater blower motor? mmerlina Jeep CJ Forum 13 03-26-2008 08:57 AM
question (another) on chevy blower motor update Kingair Pilot Jeep CJ Forum 6 03-16-2008 11:07 AM
