-   -   Chevy Heater Blower Motor (http://www.jeepforum.com/forum/f8/chevy-heater-blower-motor-293665/)
MuddyMules 07-16-2006 08:12 PM
Delete
tomthbomb 07-16-2006 08:36 PM
Doing the same thing this week. Got a Siemans PM102 motor from ABC Auto parts for $22. I almost made the mistake of buying one with the same motor except the shaft was 1/2" longer. Anyone doing this be sure to measure.
Hunt_Nevada 07-16-2006 10:42 PM
Congrats & Thank You!
That's a great post. Thanks for taking the time and sharing it with us. Looking forward getting it done in mine now....even though it is 100 degrees. Winter will be coming, and nice to know I can get that heat movin' on through the cab.
:thumbsup:
jeepsarecool 07-16-2006 10:57 PM
I think I only paid about 13-14 bucks when I did mine two or three years ago. Check autozone.
MuddyMules 07-16-2006 10:57 PM
Delete
dave_dj1 07-16-2006 11:31 PM
how hard is the fan motor to get to? looks like it could be a real pain on my 85 cj7, does the heatbox come out hard?
thanks,
dave
jeepsarecool 07-16-2006 11:41 PM
thanks,
dave
It's not as hard as it looks. There are 4 or 5 bolts under your hood on the firewall that hold it in. After you take those out it's still a pretty tight squeeze to get it out, but it will come out.
MuddyMules 07-17-2006 12:09 AM
Delete
tomthbomb 07-17-2006 12:52 AM
While you have it all apart you might want to consider replacing the heater core.
IWantAGladiator 07-17-2006 02:36 AM
and while you are at it, clean the squirrel nests out of the vents. i think the PO of my CJ kept it parked in the woods...
solitudetree 07-17-2006 05:34 AM
If you take the passenger side seat out, you'll have more room and you'll be grateful for it.
Also, check the fit of the hole after you enlarge it for the blower motor to make sure it fits correctly before you put the blower motor back in the heater assembly.
beastofacj 07-17-2006 06:18 AM
I replaced my blower motor with one out of a YJ, I too had to enlarge the opening in the firewall, but now my defroster is like a leaf blower. Now all I need is a larger alternator to power it at full blast.
tomthbomb 07-17-2006 06:22 AM
The only problem I had was the dual battery tray had to be raised for clearance.
jeepwhore 07-17-2006 08:40 AM
Does anyone have any pics of the cable routing? I did my YJ tub swap last year and finally replaced the YJ heater for my old CJ one (with blower upgrade) this past weekend. I have the defrost cable hooked up but there is a small triangular bracket/pivot with a cable going into the heater box and I don't know where it bolts to.
weprint 07-17-2006 09:12 AM
The Chevy blower motor has a cooling vent hole for the motor while the Jeep motor does not. I assume you must seal this hole to keep water and debris out. Does this cause any problem with the life of the motor? Thanks.
The time now is 09:35 PM.
