Chevy 350 Install - JeepForum.com
post #1 of 10 Old 02-02-2006, 10:48 AM Thread Starter
OnlyNACJ
Chevy 350 Install
I want to install a 350 into my 86' CJ-7. Can anyone tell me what tranny is best for this? Also, what transfer case is best. Obviously, I am somewhat green in this area, but to save some green I want to try doing it myself. I live in FL, so the landscape is basically flat. I'll be using the Jeep to run around town and occasionally to get into the backwoods for camping. I have also heard that this conversion makes a jeep tougher to handle? Is this true? Maybe I should just keep the 258?
OnlyNACJ is offline
post #2 of 10 Old 02-02-2006, 11:41 AM
flagstaffjeeper
hey dude-
what kind of tranny do you have right now? depending on what you already have, you may want to stick with that.
regarding your transfer case, you should have a dana 300, which is an outstanding unit. you would definitely want to retain that with any engine swap.
Current Jeep: 2006 Unlimited Rubicon
Previous Jeep: 1981 CJ7, 4.2L, Muncie SM465, Dana 300 t/c, Dana 30 Front, AMC 20 Rear
flagstaffjeeper is offline
post #3 of 10 Old 02-02-2006, 11:57 AM Thread Starter
OnlyNACJ
I'm almost embarrased to say, but I don't know. I'm assuming the tranny is stock. Any advice on how to find out. Where do I look. Was there a standard model on 86's? This all new to me, so I'm learning.
OnlyNACJ is offline
post #4 of 10 Old 02-02-2006, 12:48 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You've got a few different possibilities depending on your ability, wallet and time. I recommend doing alot of research before you take any action. Hit a few Jeep Forums and do a search on "350 Swap"... "SBC Swap"... "Engine Swap"...etc. There's a ton of info out there. Basically, it's gonna depend on your vision of the finished product. A daily driver/mild wheeler won't need the power/beef as say a dedicated hardcore trail rig.
For your 86.. if it's a 5 speed it's a T5 tranny. Pretty weak behind a V8 but it could survive if you drive it sanely. Honestly, I'd look for a 350 engine/tranny combo out of a running vehicle. Second option.. a 350 mated to your current tranny with an adapter bellhousing. Also gotta remember that a 350 is gonna require cooling system upgrades and a new exhaust system.. in addition to new engine mounts...etc.
BESRK is offline
post #5 of 10 Old 02-02-2006, 01:04 PM Thread Starter
OnlyNACJ
Thanks for the great advice. I'm starting to think that I should keep it simple for now and keep it stock. It is probably safe to assume that I have a 258, T5, Dana 300. I'll look for those indicators. Thanks again!
OnlyNACJ is offline
post #6 of 10 Old 02-02-2006, 10:09 PM
thiswebs4u
Check out this website:
http://www.advanceadapters.com/
My 1979 has everything stock with the adapters. You will love the 350 in these Jeeps.
1979 CJ-7, Chevy 350, edelbrock 600 cfm, mild rv cam, T18A, D30 front D44 back (locked).
2004 Grand Cherokee Limited.
2004 PSD Superduty 4x4 supercab shortbed.
thiswebs4u is offline
post #7 of 10 Old 02-03-2006, 08:45 PM
Ezredcj
Ezredcj's Avatar
1980 CJ7
I used my stock T-176 trans and it takes a good beating. The only thing to watch for is all your oddball things: radiator hoses, belts, pwr steering pump & mounts etc...
1980 Cj-7 1979 350 with mild goodies
T-176 4spd. 33x12.50 Micky Thompson Baja belted. (Complete frame off comming soon!)
SOLD 1999 Cherokee classic Rusty's 4.5 AAL 33x12.5 Maxxis Bighorn mudders.
2005 Toyota Tundra spectra blue 4x4 double cab
Hers
1999 Wrangler aka "the beast" 4cyl automatic
Ezredcj is offline
post #8 of 10 Old 02-03-2006, 11:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I think you hit this on the head. The best bet is to formulate a long term plan to modify your Jeep to your needs. This includes tires, lifts, traction diffs, brake mods, ect....While you are doing this, spend some time driving your Jeep and getting to know it. You might be suprised how that list will change as you get better at wheeling and refine its application.
jeepdaddy2000 is offline
post #9 of 10 Old 02-04-2006, 07:22 AM
thiswebs4u
Ezredcj,
Thanks for the picts, now I know how to hook up the heater in mine.
post #10 of 10 Old 02-04-2006, 12:33 PM
brettv
While we are on the subject I also need transmission recomendations. I have a 350=sm465=np205tc. I do mostly driving on the Hiqhway and need another gear. Can someone recommend a 4 or 5 speed that would bolt to the existing transfercase and bellhousing. Thanks for any help
brettv is offline
Install a Chevy 250 in '84 CJ7 (has factory 150) SethVIII Jeep CJ Forum 19 06-17-2009 01:45 AM
Chevy small block install CJ5 wyrenuts Jeep CJ Forum 2 05-03-2009 07:38 PM
chevy 5.3 seapig100 Jeep CJ Forum 1 03-10-2009 02:58 PM
chevy 350 help FF151DJG Jeep CJ Forum 4 04-16-2008 06:06 AM
T-150 to Chevy 350 Andrew1978CJ5 Jeep CJ Forum 11 04-12-2005 04:10 PM
