Checking caster angle... - JeepForum.com
post #1 of 6 Old 11-23-2007, 10:52 AM Thread Starter
79cj7reny
1979 CJ7
I checked my caster angle on top of the upper ball joint stud. I used a protractor that slides onto a steel ruler and has a bubble level on it. I put the ruler on the castle nut and rotated the protractor until the bubble showed level.
Is that the right way to get an accurate reading? I have a 3" lift and it shows the caster at 2*, which seems to make sense. Before I did the lift it was at 4*
and still wandered a little, so I was thinking of using 4* shims, which would give me 6* of + caster. Any thought on this? Thanks
79cj7reny is offline
post #2 of 6 Old 11-23-2007, 11:14 AM
spk454
1983 CJ8
factory i believe is 4 degrees, might want to just use the 2 degree shims
spk454 is offline
post #3 of 6 Old 11-23-2007, 01:50 PM Thread Starter
79cj7reny
1979 CJ7
Before I put the lift on it was at 4* but still wandered. All steering components were new so I figured 4* wasn't quite enough. Now that I lifted it, thought maybe 6* would be better.
post #4 of 6 Old 11-23-2007, 03:57 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
4* shims should be okay. Make sure to use steel shims up front and not aluminum. The aluminum shims have been known to crack across at the centering pin hole and then spit out from between the spring and perch... not good on a steering axle.
BESRK is offline
post #5 of 6 Old 11-24-2007, 03:32 PM
evil-ant
If you have 4* and still wander check everything else, steering box,ball joints tire pressure, alignment, loose spring bushings, drag link angle, ect,ect.... If the castor is set to 4 deg. then it's correct. Something else is causing it.
evil-ant is offline
post #6 of 6 Old 11-24-2007, 07:14 PM Thread Starter
79cj7reny
1979 CJ7
Everything is new. Drag link is perfectly parallel with the tie rod, new springs/ bushings, reman. steering box, all steering box mounting bolts are tight, no cracks in the frame around steering box bolts. I'm having the alignment checked this week. I'll figure it out eventually, I'm just a little slow (trying to graduate from Remedial Jeep 101 )
How do measure caster angle? scarlett Jeep CJ Forum 3 05-23-2009 05:40 AM
Another Caster angle questions Dad03 Jeep CJ Forum 1 02-23-2009 06:43 PM
caster angle questions (I read the sticky) Kingair Pilot Jeep CJ Forum 5 05-06-2008 07:08 AM
caster angle ? drunkenrich Jeep CJ Forum 2 02-11-2008 07:13 AM
Caster angle question jode Jeep CJ Forum 8 01-23-2007 04:41 PM
