Check this out! - JeepForum.com
post #1 of 26 Old 08-15-2004, 02:34 PM Thread Starter
jadams68
jadams68's Avatar
Thumbs up Check this out!
I finally ditched the carb and went fuel injected...
Look at all the fun, crappy AMC junk you get to toss!
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #2 of 26 Old 08-15-2004, 05:19 PM
fredrader
fredrader's Avatar
1947 CJ2A
That is cool..A list of parts ,cost and where to purchase everything is needed... Man I hate this obsession...(Not)
90XJ Limited 4x4,4.0 Auto,NP242
Rustys 4.5" lift D30/D35,3.55 gears
Denman Farmhand Tractor Tires 33x9.50x16
Work in progress
fredrader is offline
post #3 of 26 Old 08-15-2004, 07:57 PM Thread Starter
jadams68
jadams68's Avatar
Howell TBI injection straight from Howell was 865.00
Cheapo Air filter and assembly was $13...
I'm doing a writeup on it...
jadams68 is offline
post #4 of 26 Old 08-15-2004, 08:12 PM
fredrader
fredrader's Avatar
1947 CJ2A
Great,Looking forward to reading it...Thanks
Work in progress
post #5 of 26 Old 08-16-2004, 08:36 PM
Jeep Daddy
Jeep Daddy's Avatar
How did you get that price? Can anyone get that price thru Howel? How much of the emission stuff do you have to leave on for it to pass emissions testing....
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #6 of 26 Old 08-16-2004, 08:47 PM
hot rod
You will love it !
84'cj-7,258,tbi,hei,176,300,4.10's,Detroits,33ltb's,warn 8000
hot rod is offline
post #7 of 26 Old 08-17-2004, 08:58 AM Thread Starter
jadams68
jadams68's Avatar
I got the price doing a group buy through Howell.
The only emissions based equipment that you keep are:
- PCV to purge canister.
- CTO to purge canister.
That's it folks... You don't even keep the charcoal can...
jadams68 is offline
post #8 of 26 Old 08-17-2004, 11:46 AM
Striider
Striider's Avatar
It depends, on my 84 CJ7, here in Colorado, I had to order the emissions legal California kit, which has an O2 sensor, speed sensor and you keep the charcoal canister as well. All the EGR crap was tossed, and the tell you to cap the EGR systemcoming out of the catalytic converter (which I had done years ago actually).
I wish I knew how he got his for that price though, mine was $1100 I think.
84 Jeep CJ7, Rebuilt 258 CID with Howell TBI, TFI Ignition Mod, 4" Spring Lift, 1/2" Conn-Ferr Shackles, 33" Yokohama Geolander MT's, One Piece Axles, AMC 20 Detroit Locker, Dana 30 Front Lincoln Locker, Superwinch Hubs, Custom Built Bumpers/Rear Crossmember combo
Striider is offline
post #9 of 26 Old 08-17-2004, 06:09 PM
CorryDiller
How many do you have to buy to get the group price?
CorryDiller is offline
post #10 of 26 Old 08-17-2004, 06:53 PM Thread Starter
jadams68
jadams68's Avatar
Well I messed up a few things... The price was 965...not 865, so now everyone will flame me for screwing up...sorry!
And yes you need the o2 sensor and speed sensor for emissions, I was mainly thinking about the emission hoses.... strike 2 for me.
And lastly... I guess I -=-=-=-=-=-=-=-=ed up because I never put the charcoal can back... instructions failed to mention it.
jadams68 is offline
post #11 of 26 Old 08-19-2004, 09:54 PM
Striider
Striider's Avatar
I screwed up too...mine was $1195 direct from Howell, and no one ever replied to my request to be part of a group buy on a forum I read a few months back, so I don't know how many people it takes. I try to forget how much money I spend on my Jeep so it doesn't hurt so bad
The only problem I had with the kit is the fuel pressure regulator gasket on the rebuilt throttle body was pinched and started to leak fuel into the throat of the unit within 30 minutes of first startup. Took me an extra 30 mins or so to get that apart and together correctly, as it has a tricky spring in there.
Striider is offline
post #12 of 26 Old 08-20-2004, 11:25 PM
Later_THANKS
Later_THANKS's Avatar
You 6 piston dudes crack me up.
Get totally rid of that crap and put in a chevy 350.
Rob99 Fan Club Member#00
Beware users with very thin skin:
gschretter
Later_THANKS is offline
post #13 of 26 Old 08-21-2004, 12:05 PM
jeepmor
jeepmor's Avatar
Thumbs down Howell tips
An 80's era chevy truck V-6 thru v-8 model air cleaner housings fit on that Howell TBI nicely. I was even able to keep my fresh air intake working and it uses a larger diameter air cleaner.
Nice tossing all that 80's emissions stuff huh. Worth more for weight in the copper wire than anything else.
jeepmor
jeepmor is offline
post #14 of 26 Old 08-21-2004, 02:32 PM Thread Starter
jadams68
jadams68's Avatar
Sure and then I can have a carbed V-8 350 with more horse power than is ever needed and less gas mileage stall on me too. Good suggestion.
jadams68 is offline
post #15 of 26 Old 08-21-2004, 08:18 PM
rcsutton
2010 JK Wrangler
Does it run ok on 87 Octane? What about the Holley Pro injection set up. It's around $700.00?
2010 2 door JK Red Rubicon.
rcsutton is offline
liquid check = rollover check??? meater Jeep CJ Forum 21 03-10-2017 10:39 AM
With oil pan off. What else should I check? shok47 Jeep CJ Forum 9 09-09-2009 03:21 PM
Check this CJ out !!! LGTWhisky Jeep CJ Forum 19 06-26-2009 09:12 AM
what is a jumper wire to use to check the check engine light codes. vilentj Jeep CJ Forum 3 07-09-2008 08:29 PM
Rollover Check Valve & Fluid Check Valve -Parts search CJPoorhouse Jeep CJ Forum 2 06-13-2004 07:13 PM
