Check it or not - JeepForum.com
post #1 of 5 Old 07-27-2013, 01:07 PM Thread Starter
boojeep
1979 CJ5
Check it or not
My sending unit just arrived. Do I assume its all ready to install or double check the settings for my gauge first.
boojeep is offline
post #2 of 5 Old 07-27-2013, 01:11 PM
MoC
I would 100% check it so you don't have to drop the tank again.
MoC is offline
post #3 of 5 Old 07-27-2013, 02:25 PM Thread Starter
boojeep
1979 CJ5
Alrighty then.Better safe than sorry. To the garage I go.
boojeep is offline
post #4 of 5 Old 07-27-2013, 03:47 PM Thread Starter
boojeep
1979 CJ5
Check the ohm values,with some tweaks on the empty side I have 70 ohms. Half full position reads 26 and full reads 14. Is that close enough? Hoping John sees this.
boojeep is offline
post #5 of 5 Old 07-27-2013, 07:58 PM
keith460
Jeep. There's Only One
keith460's Avatar
That's pretty close but I would still try to get it a little better if you can.
One of the other things you should do is verify the stoke length of the float arm. Measure the inside of the tank from top to bottom and adjust the swing of the arm so when it is empty, the float will reach bottom. Same as the top of the swing of the float arm when full. Adjust arm as needed and then check Ohms again to verify.
1984 CJ-7 Renegade
keith460 is online now
