Cheap yet effective body mounts - JeepForum.com
post #1 of 18 Old 12-31-2013, 02:58 PM Thread Starter
cwig12
1983 CJ7
I was under my jeep today and while down there I looked at my body mounts. It's definitely time for replacements, they are split and crushed. I don't have a lot of cash right now to throw at a kit. I've been told and read that Hockey pucks work or polyurethane skateboard wheels which also give it a bit of a lift as well without having to do anything to the steering and what not. Any suggestions? This is my DD and if I do anything that pertains to off road it isn't much.
Creative-X - Web Design and 3D Printing
My portfolio:
cwig12 is offline
post #2 of 18 Old 12-31-2013, 03:09 PM
turkish6
1982 CJ8
I know a lot of guys who have used this method with TJ's and have had no issues
turkish6 is offline
post #3 of 18 Old 12-31-2013, 03:17 PM
Captainak
1982 CJ7
http://www.trailerpartsdepot.com/mmN...4%203143-4.GIF
These work very well
1982 CJ7, AMC 401, Dana 60 & 14 Bolt
http://jeepspace.jeepforum.com/Captainak
https://plus.google.com/photos/116451153412037001676/albums/5857883655447386049
Captainak is offline
post #4 of 18 Old 12-31-2013, 03:25 PM
DanStew
1963 M-38
Skate wheels would add up real quick, they are not that cheap compared to the other options.
Dan Stewart
1991 Wrangler
DanStew is offline
post #5 of 18 Old 12-31-2013, 04:52 PM
ADDZ71
1979 CJ7
For Safety's sake just spend the money. A complete set is probably right around $70 but I bet you could find a sale or something at 4WD and get some poly's cheaper. This cab be a big effort depending on the condition of the bolts and nuts which are hidden in many spots. Do a search in the Forum (use the google box on top left of any page and search "CJ - Body Mount Replacement"). Using anyother item may allow the tub to shift at the wrong time and impair braking or clutch use.
ADDZ71 is online now
post #6 of 18 Old 12-31-2013, 04:53 PM
skizriz
1978 CJ7
Body mount kits are only $30 or so.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #7 of 18 Old 12-31-2013, 05:28 PM
bptactical
I ran hockey pucks on my 77 for years with no issues whatsoever. Drilled them in a lathe, turned the spacer sleeves .020 shorter than the pucks so there was just a smidge of compression on the pucks.
I put that Jeep through hell and the body bushings were the least of my worries.
Cost was about $12.00 IIRC, I had all the pucks I could ever need.
Playing the greatest game in the world has its perks.
Pucks won't squeak like poly will BTW.
bptactical is offline
post #8 of 18 Old 12-31-2013, 05:41 PM
MikeHoncho88
2015 JK Wrangler
Never heard of the skate wheels idea. I've seen skateboards with 4 wheels at the thrift shop for $1.
MikeHoncho88 is offline
post #9 of 18 Old 12-31-2013, 06:34 PM Thread Starter
cwig12
1983 CJ7
I'm going to just use the Hockey pucks, seems like they work just fine. I was talking to my buddy who drifts and races and he said they all just use hockey pucks without a problem. I'll eventually buy an OEM set later for a 1" body lift.
My portfolio:
cwig12 is offline
post #10 of 18 Old 01-01-2014, 06:41 AM
imafishingfred
imafishingfred's Avatar
1981 CJ7
Look around the net. You could likely find them cheaper than these and won't have to make any modifications.
http://www.rustysoffroad.com/jeep-su...6-jeep-cj.html
imafishingfred is offline
post #11 of 18 Old 01-01-2014, 07:24 AM
turkish6
1982 CJ8
What is the stock body mount thickness?
turkish6 is offline
post #12 of 18 Old 01-01-2014, 07:57 AM
lucdog
1980 CJ5
No where in any sporting goods store have I seen Hockey pucks listed as body mounts. Parts books don't have body mounts listed as use for hockey pucks.
The Purpose of a body mount is to allow a little flex between the frame and tub, this would be to reduce the chance of cracking of the mounting area on the tub.
Just because drifting cars may use them doesn't make it correct. Use the correct part for the application!
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #13 of 18 Old 01-01-2014, 08:16 AM
yahwhy
1982 CJ7
Most people use hockey pucks for body lift not body bushings.
Don't know how much hockey pucks go for these days but I bet there atleast $5.00 apiece x 9 = $45.00
yahwhy is offline
post #14 of 18 Old 01-01-2014, 08:59 AM
skizriz
1978 CJ7
A future "damn PO" in the making.
skizriz is offline
post #15 of 18 Old 01-01-2014, 09:15 AM
MoC
If you can't afford to properly keep you vehicle on the road park it and take the bus. Still pay for your insurance, or making imitations of that as well?
MoC is offline
