Cheap / Faulty Parts No Customer Service-- Oconee Off Road a Jeep Parts Supplier
#31 | |
I live 20 min from Oconee Off Road, I've been there twice and will not go back. The guy behind the book knew how to use it but had no idea where anything was in the store. After looking around I realized just how unorganized the place was.
I was looking for a set of front "U" bolts for a 74 CJ5, did not have them in house. What about a set of spring bushings? Nope! They are not the first place I've been in that just did not seem to work like a good business. I wish them the best. But they will not get my business.
Be Worthy |
#32 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
There 'are' two different offsets on the nose of the waterpumps, I have run into that and have had to return one. I was under the understanding one was for the flex fan and one was for the fixed fan or they changed them at some year point and as usual the parts store had the wrong one in the right box...
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#33 |
I have had no experience with them simply becuase they haven't replied to any of my pm's.My solution has been to just take my buis.elsewhere.Oh well,their loss!
#34 | |
I posted that to help the guy above so he does not fail. There could be a machined shim to fix this rather than washers. Do not know. |
#35 |
What was I thinking
There are actually 3 pumps for the CJ all with different mounting heights. Not counting the serpintine pump. Somehow I ended up with all three in my barn at the same time. I had fun mixing pulleys and pumps together to make one work. Even the pulleys have different deck heights. I finally added a 0.060" shim and it's been great so far.
I cannot see shimming up with plates hurting anything at all. My shims were as big as the mounting flange. ![]() I made mine from some aluminum sheet I got at Lowes. Hole saws are great and a hole punch makes it go quickly. |
#36 |
Thats a nice idea john... I have hole saws too. but this fixed for me the napa one fit correctly and I was buying new parts. The aluminum&steel have galvonic corrosion so others reading might consider steel plate too.
#37 |
I recieved my sye from them in 3 days, and had no problems. They answered all of my pm's but if you want to get ahold of a business call or email them dont expect them to check forums.
Your shim looks good but i would have used something other than aluminum. |
#38 | |
I could not even get Invoices and Packing slips from them even after several requests. I purchased $400-500 worth of stuff on 3-4 orders or so and never got a written document. OConee has been on this thread by the way. There was also several issues not just one. This thread would have died a mo ago and a nice guy just like you, maybe a friend of OConnee, posted again and thread is back to life. A month ago thead had 1000 hits now it has 1250 and climbing. Things do change but a little caution does not hurt. That $60 worth of parts they stuck me with does not seem like a good deal now. I am sure. But you will never know that unless you read the thread. |
#39 |
I am poster # 27 and I added my experience to the thread after reading the negatives and then going ahead and submitting an order (finger crossed the entire time) but it turned out to be a positive experience so I thought it would be helpful for me to add my personal experience to the thread. Not friends with them, never heard of them before placing my order and I live 1000 miles away. YMMV.
TJ Sahara (with Plow) BMW 330xi (Sold!) BMW X3 65 Vette ragtop 2008 JK Sahara Unlimited |
#40 |
I've bought boat loads of doodads and hard to find stuff never with any problems. In fact I have a ship full of goodies from them sailing my way right now. Later, Dave
#41 | |
Washers, on the other hand, could allow enough vibration in the pulley body to cause a fatigue crack. Flips21 |
#42 |
CJ Power Steering Hose FITS Correctly & Lifetime Warranty
Just ordered and installed a POWER STEERING HOSE both the low and high pressure side. Ordered from ORiley and here in one day and it fits correctly and carries a lifetime warranty on both the low and high pressure hose. The HIGH PRESSURE is bent differently than the Oconne Off Road product was and does not have the excessive bend in the Oconne one. I even bent the Oconne one more to the firewall so the bend was less and it still failed. The burst you see was a small internal leak that burst the jacket and sprayed my hood with the steering fluid, then was a slow leak after that.
I have a one inch body lift and gave me the clearance to install / remove the hoses without removing the radiator mounts or droping the steering box mount. Very Cool. It seems to be a better product and has a great warranty with local stock. Just wanted to share this as a good solution for power steering hoses. I also raised the front end and flushed the system with extra ATF Fluid and turned the wheels from side to side. Fluid comes out much faster than I expected, quart goes in just 10 seconds or so. This one just fits better and has liftetime warranty and was the same price $20 I have 500 miles on the new hose and it has not failed yet. The Oconne one failed after about 900 miles of road driving. Fred ORiley Hose ![]() Oconne Off Road or The Used Jeep ![]() ![]() Last edited by Fjguercio; 05-01-2009 at 01:35 PM.. |
#43 |
I've noticed their website often lists the same parts in both Crown and Omix. I placed an order for a few things listed as Crown. Omix showed up instead. Kind of odd. Perhaps just a glitch in the way their online catalog is setup, and perhaps Crown doesn't offer many of the things Omix does.
Anyhow, I have never had any serious issues with Oconee. I like their prices and free shipping, and I probably will buy from them again. Last edited by sanddrag; 08-07-2010 at 09:38 PM.. |
#44 |
Consulting Jeep Needs
we will be happy to take back any part you don't need the all transmission mounts work from 72 to 86
Oconee Off-Road Store Wide Sale Ends Soon! Save a extra 5% when you use promo code 5save www.oconeeoffroad.com We carry the Largest assortment of Jeep Restoration Parts and Accessories from 1941-2011 at low prices ! Visit our retail store in Watkinsville Georgia Call to Order 706-534-9955 10-5 M-F/10-2 Sat We take all major credit cards and Paypal Call or Visit our web site to order. Oconee offroad blog ! Oconee Off-road facebook photo page Contact the owner of the company
#45 | |
WAY TOO FAT FOR MY CJ5
I have ordered many parts from Oconee Off Road. I have always gotten what I ordered and got it fast to boot.
I ordered a Radiator and Spring Perches from them today. ![]() Jeff
1979 CJ5 1978 Cherokee Chief CJ5 Dream/Build Sheet Cherokee Chief Dream/Build Sheet Our SBC Swap How we made a Fan Shroud |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
