Chasing battery problem - JeepForum.com
post #1 of 15 Old 11-15-2002, 12:32 PM Thread Starter
ModernPistolero
Question Chasing battery problem
If my CJ sits for more than 5 days the battery is zapped. I have traced down and checked every possible thing that I can to see what is drawing power from the battery with no luck. Although I feel this is a long shot (or maybe not), the ignition switch needs replaced (have new one, but not any time to put it in). I can start the CJ without a key, sometimes. (I know, I know....I'm just asking for it to get stolen) Sometimes it will lock like it is suppossed to and I need the key to start it, but more often than not I can hop in and fire it up without. Is it possible that since it is not locking all the time that the ingnition is remaining on (even though its in the off position) and slowly drawing on the battery?
Rebel Pride!
ModernPistolero is offline
post #2 of 15 Old 11-15-2002, 01:44 PM
dana60cj
dana60cj's Avatar
Mine used to start without the key and I had no problems with it draining batteries.
dana60cj is offline
post #3 of 15 Old 11-16-2002, 06:26 AM
rustyCJ
can you get your hands on a dif battery to see if that is what it is. if you have checked everything and nothing is on to drain the battery, you battery might just be going bad.....will take a charge just wont hold it?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #4 of 15 Old 12-11-2002, 12:17 AM
K5QM
Does the horn work properly? Had one doing the same thing, but the horn was inop. Repaired the horn wiring and have had no more problems.
Jerry
k5qm@arrl.net
K5QM is offline
post #5 of 15 Old 12-11-2002, 05:59 AM
MudLover
MudLover's Avatar
I'd go with what rustyCJ said. I had a '96 Explorer that would do the same thing. I took the Exploder to my mechanic and he checked the system for $16, and got me a new battery for about $40 (friends...gotta love 'em). I can start my CJ without a key too. Kinda takes away from the idea of my parents taking my keys away (still gota find a way to keep them from removing the plates). Oh well.
Best of Luck,
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #6 of 15 Old 12-11-2002, 08:48 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Easy way to check if you have something "drawing" on your battery:
Make sure everything is off, including your ignition, radio, etc. Pull the negative terminal off. Now go to touch it slowly to the corner of the post....if you get a spark, even small, you have something drawing your battery down or have a short somewhere, and it probably isnt a bad battery. If no spark, you have no problem, just get a new battery.
4wheeler4CJ is offline
post #7 of 15 Old 12-11-2002, 06:53 PM
werewolf7111
heres a quick idea to help you with your problem
first: lets go by the numbers ( assuming all connections and belt have been verified)
1) battery- a car battery ( wet celled storage device) needs to be checked first to ensure it isnt the problem
a) start with a known full charge and time to cool( 12 hrs sitting)
b) with a multimeter- check the OPEN circuit voltage( should be 12.6or BETTER)- then check the SPECIFIC GRAVITY- of EACH individual cell( should be 1260-1280 per cell) ( assuming CORRECT 65/35 ratio of water to electrolyte)- ( these reading must be temperature corrected)
c) check each CELL voltage ( take leads and start + and walk each cell- the voltage should be 2.1 volts per cell)( this means in the first cell, put the RED lead on the + post and the BLACK "in" the cell- then cell hop from there[ leads in each cell until the end when the BLACK should be on the post and the RED "in" the cell)
NOTE- if there is MORE than a 10% VARIANCE between cells- the batteryis BAD
d) after that, the load test- with a VM attached to the battery, get someone to crank the vehicle with the lights on( this isnt the "textbook" test as a carbon pile for controlled load is used) but look at the voltage valley- it should NEVER drop below 10.1 volts UNDER LOAD ( the correct "by the book" test is a battery should hold its rated amp/ph draw for 30 sec and not drop below 10.1)
NOW to step 2
hook the battery into the circuit again( WITH VM attached)- look for an IMMEDIATE drop in voltage( means a load is there)- if so, check the AMP DRAW of the load( need a DC ampmeter) EXAMPLE- it would take a 1 amp draw about 180 hrs to "kill" a good battery( rated at 500 cca according to BCI)- if you have one- isolate the cause
NOW to step 3 assuming all tests are good- check the alternator output( see many"mystery" problems arise from the following- a "battery" will lose app 50% of its ability at 32ºF ( thus the term COLD cranking amp)- the battery "MAY" be too small for the ambient temperature ( example- a 500 CCA battery @32º is a 250 amp battery- assuming a starter load of about 150amps to turn[ with radio memory etc]you "may" be pushing the limit ( this accounts for a lot of " once i jump it, it works for a while" type problems)-check the alternator UNDER LOAD( cut everything on and compare it with the RPM/RATING of the alternator- if not in spec, rebuild/replace the alternator)
after all that- if you still have problems- let me know
( testing procedures courtesy of BCI and Johnson Controls)
Joe MSME PE
werewolf7111 is offline
post #8 of 15 Old 12-11-2002, 11:05 PM
rednek
rednek's Avatar
This is the quickest and easiest way. If you want you can also leave the battery post off for a week and put it back on. If the vehicle cranks and the battery isn't dead, It is in the wiring not the battery. Also check for corrosion and wore connectors on the battery. I had the same problem and never could find the draw so I put a battery cut off on mine - helps with someone driving off with your JEEP (no key problem also).
1980 CJ7
AMC 304 w/ Edelbrock 600cfm 4 bbl and home built snorkel
4 speed trans
3" Body lift
4" suspension lift
37 x 13 x 15 Boggers
15 x 10 Soft 5 rims
2 1/2" spacers
8000 lb Warn upright
1/4 turn hubs
Headers
CD changer and casette player w/ Orion amp and 10" bass tube, 2 - surface mount waterproof highs and 2 - 6 x 9 waterproof speakers
KC takedowns w/ homemade window mounts
Lock'd Rear
Flatfendered
Custom confederate flag paint job and DIXIE air horn
rednek is offline
post #9 of 15 Old 12-12-2002, 07:19 AM
4wheeler4CJ
Eric BSCE P.E. (Bachelor of Science Civil Engineering, Professional Engineer)
Just busting, werewolf....I'm an engineer also, but I am the type to go for the simple, easy "fixes" first, especially with Jeeps. I like to keep it simple and practice common sense. I will, however, keep the battery testing procedures in mind if I ever have the need to go there.
As far as batteries go, I always buy the largest CCA rated battery that sears sells, in "Die Hard Gold", costs about $85 or even less if you catch a sale, and I never have a problem, as long as I don't have a short somewhere.
I do like the battery-cutoff idea, and am considering it for my current project. I have a very slight drain occurring somewhere also, and can't track it down, as is the case with most CJ's. All wiring is brand new, done by the previous owner. I got this Jeep in trade for some parts. I got everything working finally, but I do still have a very small drain. I'll be going the cutoff route I think. THEN I'll buy a new battery, as I am operating on a sacrificial one now.
Draining a battery constantly and then recharging will severely shorten a battery's life, by the way. So, before spending good $$$ on a Die Hard Gold, either fix a draining problem or use a cutoff.
post #10 of 15 Old 12-12-2002, 08:24 AM
dallen
cutoff switch
I used to use a cutoff switch but took it out. They, at least the one I had, tend to oxidize between the plates where the knife slides in to open and close the circuit. On several occasions I would be on a run and start the rig over and over and all at once nothing. I would have to take sandpaper to the contacts and bingo, everything was ok until the next time. Just my experience with cutoff switches.
dallen is offline
post #11 of 15 Old 12-12-2002, 08:44 AM
4wheeler4CJ
That may tend to happen, but they sell oxidation-fighting compounds that I use myself on my battery terminals. It is a conductive material (doesn't inhibit conductivity) and totally prevents oxidation if kept coated. The stuff is so gooey, once you put it on, it usually won't come off anyway, LOL.
post #12 of 15 Old 12-12-2002, 05:25 PM
werewolf7111
gee Eric- a BSCE? hmm ( thats ok, I wont hold that against you LOL)
I understand and agree with you, however your customers ( the roads and buildings) dont raise near as much H@@L as mine do with me( the mechanical and electrical[ I'm actually a BSEE,BSMEand MSME while plodding thru as a doctorial candidate] and the often "less than qualified" types who service them) ( Im SURE you "know what I mean" LOL)
with that said, i probably do "over-tech" things but it seems every time i dont, i get blasted for it and have learned from experience in RCA, FMEA and troubleshooting- the greater the accuracy there- the better in the long run from both cost and problems. So sum it up simply ( out of respect for another engineer)
as we say in the army- the more you sweat in training, the less you bleed in battle
as we say in the south- measure twice- cut once
see, i can be short and simple too LOL
Joe MSME PE
post #13 of 15 Old 12-12-2002, 09:30 PM
SamFromCO
SamFromCO's Avatar
The "check for spark thing" didn't work on mine because of the clock in the radio that stays on all the time. I know this because when I first hooked up my battery and it sparked (very slightly) it drove me crazy until I found the cause.
SamFromCO is offline
post #14 of 15 Old 12-13-2002, 07:07 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
I didn't read all of the posts but, I would go to the nearest garage and have them do a load test on the battery and eliminate that first.
The load test will tell you if you have a bad cell or not and a bad cell can cause what you are talking about.
If after you try all of the rear of the good ideas above try this mine if all else fails.
Good Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #15 of 15 Old 12-13-2002, 07:23 AM
4wheeler4CJ
To properly have "everything off", you simply undo the wirenut that supplies your radio/clock power. Easy to get to under a CJ dash.
battery problem on my 78 cj7 lineguyj82 Jeep CJ Forum 3 09-24-2008 02:03 PM
Chasing Down The Last Of My Steering Slop Oily Jeep CJ Forum 7 09-18-2007 12:55 PM
CJ Battery problem David Richards Jeep CJ Forum 11 12-13-2006 05:36 AM
Is this a battery problem? n3480h Jeep CJ Forum 17 04-07-2005 04:56 PM
chasing electrical problems rusty86cj7 Jeep CJ Forum 5 10-29-2003 03:39 PM
