charcoal canister help needed - JeepForum.com
post #1 of 17 Old 04-24-2013, 04:31 PM Thread Starter
skizriz
1978 CJ7
Here's what I have. I popped the cap off that says "do not remove" and found nothing. I was expecting to find a diaphram from what I have read.
The strange part to me is that I can't blow through the nipple on the cap. There is no hole for the vacuum to operate the diaphram. I looked, and cleaned, and poked around with wire to try to find it, but it's completely sealed as far as I can tell.
Is the diaphram just smashed down solid?? I can't figure out what's going on.
Everything else seems OK. I don't want to break it, or order a new can, and find out the diaphram is there, just stuck.
skizriz is offline
post #2 of 17 Old 04-24-2013, 04:41 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
This link explains the function of the canister, and how to test it.
Good luck,
Matt
Matt1981CJ7 is offline
post #3 of 17 Old 04-24-2013, 04:53 PM Thread Starter
skizriz
1978 CJ7
I've been reading whatever I can find.
What doesn't make sense to me is that I am sitting here with the cap, and the nipple in my mouth, sucking and blowing until my eyeballs are ready to pop out of my head, and there is absolutely nothing happening.
The diaphram is either there, and stuck tight.
Or missing, and the hole for the vacuum to move the missing diaphram is clogged up, and I simply can't find it.
I can't find a picture of the underside of the cap to compare to.
The cap feels like i't just thick plastic, but has a rubbery look to the underside.
skizriz is offline
post #4 of 17 Old 04-24-2013, 04:59 PM
hasselback
I'm going to the junkyard this weekend to raid some parts from a Wagoneer. They got the same canister. Want me to grab ya one in exchange for those visors?
hasselback is offline
post #5 of 17 Old 04-24-2013, 05:08 PM Thread Starter
skizriz
1978 CJ7
I've been reading about using one from a Grand Cherokee. I can pick a new one up at Advance Auto for $25. For what it costs, I might as well just grab a new one.
You can grab me a 401, th400, and Q-trac setup though.
J/K but would be nice......
skizriz is offline
post #6 of 17 Old 04-24-2013, 05:52 PM
hasselback
Haha, I'll see what I can do. You still got those visors though?
post #7 of 17 Old 04-24-2013, 06:05 PM Thread Starter
skizriz
1978 CJ7
Yep. Still tucked away up on the shelf waiting for ya'.
Sent from my iPod touch using JeepForum
skizriz is offline
post #8 of 17 Old 04-25-2013, 02:45 AM Thread Starter
skizriz
1978 CJ7
Anybody? Before I scrap the canister.
skizriz is offline
post #9 of 17 Old 04-25-2013, 06:29 AM
thompsoj22
the pic isnt clear
but are there small bleed holes on the underside?. i would try and blow air in from the underside of the cap and see if it is released through the nipple. im guessing you wouldent want vacume to have an effect on the nipple cause it would cavitate the fuel tank. it should only allow trapped pressure to escape? i know the purge signal sllows vac to be applied to that cap but it dosent evac from that port. possibly a built in vac delay valve in the cap?
thompsoj22 is offline
post #10 of 17 Old 04-25-2013, 06:38 AM
Nafpu
2012 KK Liberty
Sig-worthy!
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #11 of 17 Old 04-25-2013, 01:24 PM Thread Starter
skizriz
1978 CJ7
From what I understand, there is (should be) a diaphram under the cap. When it gets vacuum, it sucks in the diaphram, and uncovers a port in the part of the canister that the cap goes on to (There are two ports, one sitting higher than the other).
The vacuum acts as a switch, opening the ports via the diaphram only during high vacuum situations.
skizriz is offline
post #12 of 17 Old 04-25-2013, 01:25 PM Thread Starter
skizriz
1978 CJ7
Originally Posted by Nafpu View Post
Sig-worthy!
Kind of creepy now that I read it....
skizriz is offline
post #13 of 17 Old 04-26-2013, 11:16 AM
Nafpu
2012 KK Liberty
I am sure this isn't the place for this, but Skizriz, what is your avatar? I have seen the .gif, and I have never figured it out...
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
post #14 of 17 Old 04-26-2013, 01:51 PM Thread Starter
skizriz
1978 CJ7
NOM NOM NOM......
No idea. I found it one day and kind of liked it. A little bit creepy looking when he's in action..
skizriz is offline
post #15 of 17 Old 04-26-2013, 09:55 PM
Nafpu
2012 KK Liberty
NOM NOM NOM......
Yes indeed! Almost cute in you avatar, not-so-much in action...
95 YJ, gone...
80 CJ7, gone...
Nafpu is offline
