changing t176 1st gear ratio - JeepForum.com
post #1 of 4 Old 07-22-2010, 02:31 PM Thread Starter
aero mech
aero mech's Avatar
1980 CJ7
This may be a no brainer for some of you but in a few mounth I'm rebuilding my t176 along with my engine. I was wondering if it is possible to install a different 1st gear that would give me a little more power while in 2wd? I have 4.10 gears and a 4 to 1 kit installed. I just wish for a little more power on the street. Thanks Clay
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline
post #2 of 4 Old 07-22-2010, 02:51 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
The T-177 is the same tranny, with longer output and slightly lower first gear....I guess it's possible to put the guts of one in a 176, but haven't actually seen a writeup on how.
Don't think it'd be worth it, though....T-176 first gear is 3.52, T-177 is 3.82.
Pacfanweb is offline
post #3 of 4 Old 07-23-2010, 10:44 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Your gearing isn't really off with 4.10s and a 1:1 top gear. I'd consider adding power to the motor as another option.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #4 of 4 Old 07-24-2010, 07:43 AM
Happy Joe
I had a t-176 and switched the internal gears to gears from a 177? (the lowest first gear transmission of the series, might have been a 178) because of the poor first gear ratio of the 176.
It really didn't make much difference, certainly not enough to justify the effort/expense.
If doing it again I would switch to a 5 speed transmission with a better first gear ratio (4:1) and over drive. I went to a worn out t-5, after the gear experiment (because it was available) but the NVG-35XX series of transmissions is a better option, IMO. I like the 4:1 first gear even spread transmissions much better than higher first gear transmissions or granny low transmissions, both on street and off road. I too have a 4:1 low range transfer case; having tried it with both the t-176/177/178 and the t-5, like the 4:1 transfer with a 4:1 first gear 5 speed the best of every combination that I have driven. The runner up is a 4 speed 4:1 tranny but due to non-sincromesh first, lack of overdrive and very poor shifting I cant recommend the non granny low t-18s (or the granny low versions for that matter).
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
changing gear ratio issues allornothin Jeep CJ Forum 4 05-31-2009 06:28 AM
T176 Stuck In Gear!!! Hondaluvr1985 Jeep CJ Forum 0 05-30-2009 06:19 PM
T176 Gear and Syncro Pictures...need advice before ordering parts 243 Jeep CJ Forum 1 02-22-2009 05:34 PM
AMC 20 Gear Ratio? EtownCJ5 Jeep CJ Forum 17 03-26-2008 09:31 AM
T176 Tranny stuck in gear sampson9dk Jeep CJ Forum 3 07-06-2003 04:25 AM
