changing ring and pinion - JeepForum.com
post #1 of 2 Old 06-30-2003, 05:54 PM Thread Starter
Daniel W
I found a set of Dana 30 front & rear AMC 20 cheap and in good shape to replace my old shot rear end AMC 20 but the ring and pinion are different. So how hard would it be to swap ring and pinion front and back? Is this something I could do or something for the pros. I understand you have no idea my knowledge but I am very mechanically incline just donít have a lot of experience with vehicles. One of the reasons I bought my jeep was to play around with the mechanics of it. The only problem with the new axels is it is geared at 2.73. Sounds great for the racetrack not for the backcountry.
Thanks
I just want my jeep back and running.
Daniel W
1980 CJ7 Auto I6 258
Daniel W is offline
post #2 of 2 Old 06-30-2003, 06:18 PM
fuzz401
1978 CJ7
the 30 probly wont be to bad just swap every thing with one rear to the other watch there are shims under the pinion head bearing race you will need these and the shims under the pinion tail bearing replace every thing as a unit and ck the back lash when you have every thing together to make shur it is right
the 20 is going to be a pain first the taper axels to get apart unless you unbolt the brake lines and take it off with the backing plate then watch out for the shims that go on the outside of the carrior bearings when you pull the carrior out they will fall and you need to keep each side with the side it came from the pinion uses a crush sleeve to set the pinion preload try not to damage it and watch for shims under the pinion race too reassy and ck back lash
hopefully it will be right never know from case to case
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Changing ring and pinion AMC 20 and Dana 30 Jeep Daddy Jeep CJ Forum 10 10-27-2010 05:02 AM
Help with Ring and Pinion Krackalacka Jeep CJ Forum 3 07-07-2009 08:37 PM
Ring and pinion DeltaSigCJ5 Jeep CJ Forum 10 06-18-2007 04:30 PM
CJ Ring & Pinion Help !! emersonjeep Jeep CJ Forum 5 07-02-2006 11:18 PM
Changing Ring & Pinion minich21 Jeep CJ Forum 2 09-14-2004 06:07 AM
