Changing The Ignition Lock Cylinder-CJ7 - JeepForum.com
post #1 of 20 Old 05-06-2012, 10:18 AM Thread Starter
amir_abbas
1978 CJ7
Hi friends ...
I want to change the ignition lock cylinder of cj7.
Do have any images of yours on how to change it?
amir_abbas is offline
post #2 of 20 Old 05-06-2012, 11:54 AM Thread Starter
amir_abbas
1978 CJ7
no idea?
post #3 of 20 Old 05-06-2012, 12:07 PM
jeepwhore
http://www.jeepforum.com/forum/f8/84...27/index2.html
Post # 17 in the above link has links to all the sections of the '84-'86 Factory Service Manual. It covers every aspect of those years and can walk you through pretty much any repair procedure.
I believe yours is a '77 but the procedure should still be quite similar.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 20 Old 05-06-2012, 12:41 PM
DougE
1983 CJ7
Do a search. Lots of info on this forum. Pretty good pictorial here:
http://www.jeepforum.com/forum/f8/78...t-key-1152916/
1983 CJ7, 258I6, T4, Dana 300, 31x10.5x15 DuraTrac
DougE is offline
post #5 of 20 Old 05-06-2012, 12:51 PM
DougE
1983 CJ7
If you only need to do the ignition switch you can do it in the vehicle without removing the column. Once you have reached the turn signal assembly, slip it over the column and off to the side and you can access the clip or screw that retains the ignition switch. Search and you will find info for just the ignition switch replacement.
DougE is offline
post #6 of 20 Old 05-06-2012, 12:59 PM
WindKnot
1977 CJ7
Filling out your profile can really help us when it comes time to do research. If we know what you're driving we can eliminate things that don't apply to your vehicle.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #7 of 20 Old 05-06-2012, 02:28 PM Thread Starter
amir_abbas
1978 CJ7
I searched but...
Thank you all!..still I can't find anything...
Where is the exact place of the screw??!
post #8 of 20 Old 05-06-2012, 03:45 PM
DougE
1983 CJ7
This should fix you up:
http://civilianjeep.info/Strenk/Stee...placement.html
DougE is offline
post #9 of 20 Old 05-06-2012, 03:49 PM
scooter71954
2016 JK Wrangler
be advised. Regular GM cylinders work great, but NOS AMC keys won't fit. You must have an AMC cylinder. AMC keys are thicker.
I love to have an AMC key on my keyring. I't an AMC Jeep thing.
scooter71954 is offline
post #10 of 20 Old 05-06-2012, 06:30 PM
John Strenk
John Strenk's Avatar
1976 CJ5
last link in my sig.
if you have a non tilt wheel
John Strenk is offline
post #11 of 20 Old 07-01-2012, 09:29 PM
mlevario99
1978 CJ7
I new to this site and to the jeeps, I just bought a 78 CJ7 last Thursday June 28. It has no key but I am able to start the engine without the key, so I decided to replace the cylinder, which I was able to do, but the cylinder does not turn all the way back, so I am not able to remove the key, I try a few times but nothing, does any one had this problem. I read some of the post and I follow one which had pictures, what am I doing wrong. Sorry for hijacking this thread
Thanks
mlevario99 is offline
post #12 of 20 Old 07-02-2012, 02:26 AM
John Strenk
1976 CJ5
Maybe the switch is out of alignment?
Is this a tilt or non tilt steering wheel?
post #13 of 20 Old 07-02-2012, 06:36 AM
mlevario99
1978 CJ7
Is a tilt column, I try to line up the switch with the little triangle in the steering and the groove in the cylinder but cannot do it. There is a little steel leverage right nect to the cylinder, what is that for, does it have to do anything with the cylinder.
Thakns
post #14 of 20 Old 07-02-2012, 07:19 AM
John Strenk
1976 CJ5
I'm not that familiar with the tilt wheel. Can you post a picture?
post #15 of 20 Old 07-02-2012, 07:41 AM
mlevario99
1978 CJ7
I am at work right now, I will try to get a picture and post it as soon as posible.
Thanks
ignition
ignition lock an cylinder fgraham427 Jeep CJ Forum 4 04-05-2010 05:27 PM
Ignition Lock Cylinder Rocky_7734 Jeep CJ Forum 8 05-11-2009 08:59 AM
Changing the ignition cylinder startjump2 Jeep CJ Forum 1 07-30-2004 03:52 PM
ignition lock cylinder boosteddsm Jeep CJ Forum 1 06-25-2004 03:13 PM
ignition lock cylinder certifiablejeep Jeep CJ Forum 4 05-10-2004 10:54 AM
