changing diff fluid - JeepForum.com
post #1 of 7 Old 10-11-2006, 11:25 AM Thread Starter
long71
changing diff fluid
about to change the diff fluid on an 84 cj7 but the thing seems to be sealed. maybe a dumb question but a little insight would be greatly appreciated. oh and also the heater core seems to be leaking antifreeze into the passenger floorboard, maybe someone has some experience with this as well and can offer their help
thank you from the "newbie" aka Scott
long71 is offline
post #2 of 7 Old 10-11-2006, 11:27 AM
CJ51973
CJ51973's Avatar
You have to pull the cover off to change differential fluid. The heat core will have to be replaced if it's leaking. Get yourself a Haynes/Chiltons manual for you Jeep and it will get you started.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #3 of 7 Old 10-11-2006, 11:32 AM
okjeep98
okjeep98's Avatar
1983 CJ7
My heater leaked too. I just need to tighten the two clamps on the heater hoses.
83 cj7 4" lift 33 super swampers, Fuel Injected 258
If it aint broke, fix it untill it is.
okjeep98 is offline
post #4 of 7 Old 10-11-2006, 11:36 AM
AggieCJ
When my heater core started leaking on my 86 I just bypassed it. Easy to do when you live in TX. Wasn't a daily driver though. The cab used to get plenty warm from just the heat coming up from the floor and the Tranny hump.
AggieCJ is offline
post #5 of 7 Old 10-11-2006, 12:16 PM
Later_THANKS
Later_THANKS's Avatar
You aggies.
Yes, what he says is a good idea even if came from an aggie..
I guess every now and then you guys come up with some good stuff.
Rob99 Fan Club Member#00
Beware users with very thin skin:
gschretter
Later_THANKS is offline
post #6 of 7 Old 10-11-2006, 05:05 PM
thenubsterman
ya the diff cover once you take all the bolts out take a hammer with a flathead screw driver knock it between the cover and the housing and pry it off start from the bottom so you dont take a complete bath
thenubsterman is offline
post #7 of 7 Old 10-11-2006, 05:13 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
OR you could go spend 20-40 bucks on a new one and put it in and have a heater and defroster. It's not difficult. There's a few screws in the firewall holding the heater assembly in. Take those out, take the back off the duct, pop the new one in, reattact the hoses and you're good to go. I agree about buying a manual.
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
Changing diff ratios for lockers - HELP Cambo Jeep CJ Forum 1 10-21-2009 04:05 PM
Changing fluid in Qtrac transfer case pnorris Jeep CJ Forum 2 03-12-2008 08:10 PM
changing tranny fluid tolobill Jeep CJ Forum 7 09-22-2007 02:12 PM
Changing tcase, and diff fluids? dblock16 Jeep CJ Forum 1 04-17-2007 08:28 AM
Details on changing diff. gears Matt in TN Jeep CJ Forum 8 12-26-2005 05:57 PM
