changing d44 lug pattern - JeepForum.com
post #1 of 6 Old 03-12-2010, 12:39 AM Thread Starter
shok47
1983 CJ7
Is is hard to change lug patters from say, a 8 lug to 5 lug? Im searching for d44 and alot are 6 lug and more, but if I can do it easily by buying different part, then I will have a bigger selection.
Thanks
shok47 is offline
post #2 of 6 Old 03-12-2010, 02:56 AM
dtcohen
1980 CJ7
im no expert but I would say that all you would have to do would be change the hubs.
dtcohen is offline
post #3 of 6 Old 03-12-2010, 07:56 AM
No_Bs
1977 CJ5
Between changing the spindles, brakes, and hubs, you can make any D44 any bolt pattern that was available in some stock form.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #4 of 6 Old 03-12-2010, 08:48 AM
foggybottombob
On the front axle that is all true. On the back axle you would normally have to buy axle shafts which fit your housing and have flanges drilled with the right wheel pattern. There are also spacers you can buy to convert from some wheel patterns to others but I'm not a wheel spacer fan.
foggybottombob is offline
post #5 of 6 Old 03-12-2010, 10:24 AM Thread Starter
shok47
1983 CJ7
Alright, thanks guys, this gives me more options now. Just wanted to double check
shok47 is offline
post #6 of 6 Old 03-13-2010, 11:12 PM
allornothin
converting a 6 or 8 lug 44 to a 5x5.5 jeep pattern is simple.......dodge fronts work great
allornothin is offline
bolt pattern jeepheller98 Jeep CJ Forum 2 07-11-2008 05:14 PM
CJ5 Lug pattern, what else will it fit ? awachwhiteboy Jeep CJ Forum 2 09-03-2005 04:54 PM
Lug Pattern Tri_X_Troll Jeep CJ Forum 1 04-21-2005 08:57 PM
Just a lug pattern question bethanysrydthis Jeep CJ Forum 4 02-25-2005 01:00 PM
Lug Pattern IronYJ Jeep CJ Forum 4 06-30-2004 12:23 PM
