Changing a CJ rollbar to a YJ family style rollbar - Page 8 - JeepForum.com
post #106 of 111 Old 12-04-2013, 06:07 AM
ScroungerLee
The Bestop Supertop I was installing yesterday is for CJ and YJ. I am holding the instructions right now and it clearly says so.
ScroungerLee is offline
post #107 of 111 Old 12-04-2013, 08:01 PM
ThisGuyUKnow
The YJ and CJ tops are interchangeable. Bestop uses the same kit for both vehicles. Your instructions may say CJ but the parts and assembly are shared with the YJ. If you google the instructions you will find copies that say both CJ and YJ on them
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #108 of 111 Old 12-05-2013, 09:46 AM
ScroungerLee
post #109 of 111 Old 02-17-2014, 09:44 AM
Purplehaze1786
1980 CJ7
Hopefully I'm not reviving a dead thread. This weekend I added the roll bar extensions to my CJ7 (with a YJ family style roll bar) I followed others instructions on this post, and used a 5/16" nutsert. The issued I was worried about was the soft top bracket connected to each corner of the windshield (see GoJomans pics). BUT....the extension bars fit overtop of them without any issues. The ext bar holes lined up with the big holes in the soft top bracket, so I basically just drilled the center of the bracket holes, and inserted the nutsert. I didn't have the "nutsert tool", but I made my own using a thin piece of metal with a hole big enough for the bolt needed for the nutsert. Next, I put a washer on both sides of the metal, with a bolt thru them, and screwed it into the nutsert. Worked great. I'm sure my post doesn't make sense without pictures, but i'll post some tonight when I get home.
My CJ doesn't leak oil, it marks its territory.
Purplehaze1786 is offline
post #110 of 111 Old 02-20-2017, 09:32 AM
MoGas
The one in my '79 is out of a TJ, I believe. It has adjustable height for the shoulder up front and the high mount shoulder for the rear. I don't think YJs had adjustable height on the front belts.
MoGas is offline
post #111 of 111 Old 03-25-2017, 06:03 PM
jsonhd
Great write up of helpful info!
jsonhd is offline
How Much to give for a Yj Style Rollbar? elks96 Jeep CJ Forum 18 02-23-2009 12:03 PM
Old style rollbar, I need padding PhatBasturd Jeep CJ Forum 1 02-08-2008 11:12 PM
rollbar pad moach1 Jeep CJ Forum 4 10-03-2006 03:54 PM
CJ7 rollbar DEERSLAYER1407 Jeep CJ Forum 5 08-18-2004 08:04 PM
CJ rollbar CJay7 Jeep CJ Forum 6 10-24-2003 08:35 AM
