Changing a CJ rollbar to a YJ family style rollbar - Page 5 - JeepForum.com
post #61 of 111 Old 08-25-2009, 06:54 AM
mpd224
Not trying to resurrect this thread, but has anyone tried this on a CJ5? If not this the family style bars, has anyone found a way to put the bar from the roll bar to the windshield on a CJ5? I am really looking for a way to ge the bar in there so the wife and I have something to grab ahold of. Thanks
mpd224 is offline
post #62 of 111 Old 08-25-2009, 07:43 AM
DT5150
1983 CJ7
a yj cage won't fit in a cj5. your best bet would be to fab something up.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #63 of 111 Old 08-25-2009, 09:37 AM
CopperCJ7
Or buy a YJ set-up from a junkyard and mod it to fit. And the windshield is NOT the best anchor point. Better to go to the floor and then to the frame. At least check out what RockHard bolt-in kits do. Soon, the resurrected Poison Spyder will have bolt-in kits as well.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #64 of 111 Old 08-26-2009, 06:19 PM
Blthomas
Blthomas's Avatar
1979 CJ7
I'm trying to put new 3point belts in my CJ7 with the family cage. Only thing I'm not clear on is mounting of the front belt, not the spool, not the shoulder point, but the loose end.
Did you drill through the tub under the spool and mount there? All my new belts came hardware and big body washers. Like 3" diameter washers.
Bard could I get a pick of your front belts and how they mount close up?
Thanks
EDIT: Never mind, got it.
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #65 of 111 Old 02-27-2011, 09:03 PM
jatepper
I am doing this swap right now. My family bar was removed from a 95 YJ. For some reason, the bolts on the floor of the tub on the main hoop did not line up perfectly. I am referring to the 4 bolts (2 on each side) that go directly in to the floor of the tub and not the horizontal bolts that face the rear of the Jeep which go in to the wheel well. I am going to have to modify the holes to make it fit. Not a big deal, but I always thought the YJ bars were a 100% direct swap (aside from the forward bars from the main hoop to the windshield).
I eliminated the YJ forwards bars and went with OR Fab's sport cage for the CJ. It works with the YJ family cage too.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #66 of 111 Old 02-27-2011, 10:46 PM
Trapshooter
jatepper......could you post some pictures of the OR Fab's sport cage install. I am curious to see how that works for you.
Don't have any answer on the floor holes. Did this mod to a '79 CJ7 I used to have but had to drill all the holes for the forward mount on that rig.
Thanks.....Trap
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #67 of 111 Old 02-27-2011, 10:50 PM
Trapshooter
jatepper......disregard, found your other thread.
My 401 build:
post #68 of 111 Old 04-07-2011, 10:35 PM
wyoming_sal
1981 CJ7
You have to file them out. Had the same problem with mine. It doesn't take much. Than I welded 20ga washers to the roll bar and that was that.
Also do you have pics of the ORF install? I bought the brackets but was doing a fab on the bars. I wasn't sure if the 7 and yj roll bars were the same vertical angle which would affect the install.
wyoming_sal is offline
post #69 of 111 Old 04-10-2011, 09:25 AM
herCJ7
1979 CJ7
Does anyone know what the maximum height of the roll bar can be without affecting a soft top? I plan to change out my roll cage, but I don't have a soft top yet. The YJ bars measure 1" taller than the CJ bars when they're in the Jeep. Will this be enough to affect the soft top installation?
herCJ7 is offline
post #70 of 111 Old 04-26-2011, 07:52 AM
ErikEastman
If anyone is having trouble finding a good source for the nutserts, McMaster-Carr has all this stuff and they are great to work with.
I got a bag of 10 5/16-18 thread for $10, plus the tool for $30. Not a bad investment since I can see where these could come in handy for many things.
http://www.mcmaster.com/#catalog/117/3271/=c1kwiu
ErikEastman is offline
post #71 of 111 Old 08-15-2011, 02:10 PM
quentinmc1
That is a great write up on how to do this. I have an article on my site http://www.yjjeep.com that gives some information about an eaiser way. The problem is that the rollbars can be a little hard to find. This is an easy alternative. Here is the link http://www.yjjeep.com/easy-way-to-ad...o-your-cj-jeep
YJ Jeep Owner
quentinmc1 is offline
post #72 of 111 Old 08-28-2011, 06:43 PM
jkoz79
1964 CJ5
Define "Won't fit".
I am almost there
jkoz79 is offline
post #73 of 111 Old 09-03-2011, 01:07 PM
jkoz79
1964 CJ5
DONE!!!!!!!
It fit great. Tied into the frame and can now add 3 point seat belts if I want
jkoz79 is offline
post #74 of 111 Old 09-03-2011, 01:14 PM
jatepper
Originally Posted by jkoz79 View Post
DONE!!!!!!!
Were you able to use the existing roll cage mounting holes? I'm betting the forward bars will have to be cut or modified. If it fit "as-is" then that is great!
Looks good.
jatepper is offline
post #75 of 111 Old 09-03-2011, 07:37 PM
jkoz79
1964 CJ5
Looks good.
I did not have existing holes. It is a fiberglass tub. Certainly more than a bolt in but much les than a total build from scratch
jkoz79 is offline
How Much to give for a Yj Style Rollbar? elks96 Jeep CJ Forum 18 02-23-2009 12:03 PM
Old style rollbar, I need padding PhatBasturd Jeep CJ Forum 1 02-08-2008 11:12 PM
rollbar pad moach1 Jeep CJ Forum 4 10-03-2006 03:54 PM
CJ7 rollbar DEERSLAYER1407 Jeep CJ Forum 5 08-18-2004 08:04 PM
CJ rollbar CJay7 Jeep CJ Forum 6 10-24-2003 08:35 AM
