Changing a CJ rollbar to a YJ family style rollbar - Page 4 - JeepForum.com
post #46 of 110 Old 03-25-2009, 12:58 PM
DT5150
1983 CJ7
mine's a cj super top and it also fits just fine.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #47 of 110 Old 03-25-2009, 01:28 PM
jeepskate
The tops are the same.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #48 of 110 Old 03-25-2009, 01:32 PM
CJ Chet
I got straight on the "nutsert" thing and got them installed. However, going by my experiences with them, I just assumed that sometime in the future they would "spin" on me. So I brazed them in with my little Mapp torch on a real fine flame. Worked GREAT! No problem.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #49 of 110 Old 03-25-2009, 05:58 PM Thread Starter
Bard
Originally Posted by wavejd View Post
Hi Bard -
Thanks for your quite useful posting about how to retrofit a YJ family cage into a CJ. I have almost finished this project thanks to your good advice (into my '82 CJ-7).
One question I have for you is whether or not you had a problem with the length of the seat belts in the rear. Everything went in fine like in your directions and when I finally climbed in the back to try it out, I could barely get the shoulder/lap belt around my torso (I'm 6'2" / 190 lb so that shouldn't really be the problem). I also tried putting in my kids booster seat in the back. While that was a little better, it was still a tight fit.
I can probably try to rig up something to extend the length of the female end but I am curious to see if you had a similar problem. In your photos, it looks like the belt goes thru the back of the car seat which means you are not likely to see the problem. However, if you put a kid in a booster seat and the belt routing changes, you might have a problem.
Thanks again for your tips.
Jim
Sorry, been traveling alot and just logged in. I haven't tried to sit in the back. It was a full car seat in the pics. I can try the booster and see what it does in the next couple of weeks. The difference in the YJ and CJ belts(female) is about 6 inches if I recall, YJ shorter. I do not see how the extractor in the male belt would bind up or be short. It should be identical to a YJ 92 to 95 set up. Did you use the center hole for the belt changes on the female? Do you have a pic? I will get back to you when I see my Jeep.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #50 of 110 Old 03-27-2009, 01:23 PM
wavejd
Hi Bard - Thanks for the reply. I did use the YJ seat belt set with the center hole. I does come up just a little short. You don't need to try anything on your rig - I am just going to use a couple of those 12" aftermarket seat-belt extenders on the tub-side of the 3 point belt. That should take care of the problem.
Thanks again,
Jim
wavejd is offline
post #51 of 110 Old 03-28-2009, 11:29 AM
Blthomas
Blthomas's Avatar
1979 CJ7
I see you are in my state. Where did you get the nusert things? Can't get them anywhere locally...............
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #52 of 110 Old 03-28-2009, 03:04 PM
CJ Chet
I got mine at ACE Hardware.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #53 of 110 Old 03-29-2009, 10:32 AM
Blthomas
Blthomas's Avatar
1979 CJ7
GTFO. My Ace didn't even know what it was. Pm'ing ya.
81' CJ8 bone stock
Blthomas is offline
post #54 of 110 Old 04-01-2009, 07:38 PM
Tigger01
I'm in the process of doing this my self now
And have followed this post from the Begining
I had the 88 YJ roll cage that came with the 88 YJ tub
Converting this tub to fit on my CJ-7 body
I had bought the 2 side rails to the windshield off E-bay
But bought a aftermarket CJ windshield frame for the conversion
I have been looking around Richmond All week also looking for these
nutserts here I have been to Ace, Lowes and Fastenal
The only thing I have found that looks like this I have found in a Grainger Cataloge
so I ordered them and should be in tomorrow and hope these will work
had to buy a bag of 25 for $ 20.00 hope they will work they will fit a 5/16 bolt though
well guess I will have extras
But thanks for the Idea I had been Looking for an Idea to do this
the only other Idea I had was to get a 5/16 nut with the flared bottoms
( like they had on bicycle front & rear axles )
drill the holes turn the nut around and tack weld them to the windshield frame
don't think they would be as flush to the windshield frame doing it this way though
Thanks Again for the Post
tigger
Tigger01 is offline
post #55 of 110 Old 05-27-2009, 04:29 PM
kclarkcj-7
hi im planning to put in those side bars in my 86 cj7. did you make those brackets that bolt to the winsheild? thanks
kclarkcj-7 is offline
post #56 of 110 Old 05-27-2009, 07:35 PM
dhubing
The brackets seen in the picture below?
Those come on the YJ's bar.
dhubing is offline
post #57 of 110 Old 06-21-2009, 08:41 PM
NelsonATC
1980 CJ7
Thanks for the write up! Just did this yesterday and love the way it looks. Had to knotch out the back of the front bar so my windshield sat in its natural position. Short work with a carbide bit and a half round file.
NelsonATC is offline
post #58 of 110 Old 07-06-2009, 04:42 PM
Bubba Ray
I would love to do this swap to my 84 but I am not sure I saw if the hardtop will still fit. Does it?
Bubba Ray is offline
post #59 of 110 Old 07-06-2009, 05:30 PM
NelsonATC
1980 CJ7
Sorry, no help here. I only run a soft top. It looks to me like there would be some issues in its current form, as the sheet metal screw holes in my frame are now inaccessible in that spot. Sure it could me modified to make it all work, but it would take some grinding
post #60 of 110 Old 07-06-2009, 06:23 PM
longboy
2006 WK
Hard top fits fine with YJ family-style rollbars.
2006 5.7l WK
longboy is offline
How Much to give for a Yj Style Rollbar? elks96 Jeep CJ Forum 18 02-23-2009 01:03 PM
Old style rollbar, I need padding PhatBasturd Jeep CJ Forum 1 02-09-2008 12:12 AM
rollbar pad moach1 Jeep CJ Forum 4 10-03-2006 04:54 PM
CJ7 rollbar DEERSLAYER1407 Jeep CJ Forum 5 08-18-2004 09:04 PM
CJ rollbar CJay7 Jeep CJ Forum 6 10-24-2003 09:35 AM
