Changing a CJ rollbar to a YJ family style rollbar - Page 3 - JeepForum.com
post #31 of 111 Old 05-12-2008, 04:40 PM
CJ Chet
I'm having the same problem. Can't find a setting tool for a Nutsert that large, so here's what I'm going to try:
I got two bronze thrust washers, just to have some good bearing surface, and also polished up one side of the nut with emory cloth for the same reason. My reasoning is that I should be able to hold the bolt stationary and turn the nut to set the nutsert.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #32 of 111 Old 05-12-2008, 04:53 PM Thread Starter
Bard
That might work. When I got mine, there was close to 10 "tools" in the box of nutserts. I will get it tomorrow and measure it. The problem you will run into is you need a inside diameter washer where it will fit into the nutsert and spin freely, so it won't bind, that is the way the tools is designed.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #33 of 111 Old 05-12-2008, 07:18 PM
jeepskate
Originally Posted by SKT View Post
Great write-up, especially for folks who don't weld their own stuff, and/or don't want to spend a lot on a custom cage!
Looks great!
To reiterate...this is *NOT* a substitute for a cage, so don't do this and go off thinking that you have a cage and kill yourself or become a vegetable.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #34 of 111 Old 05-12-2008, 08:17 PM
SKT
Gotcha ...and 100%.
Sorry, I used the word "custom cage" loosely.
I fully understand that no way, shape, or form is this anything more than a rollbar!
I would venture to say the majority of Jeepers who own a true "caged" rig, never actual field test theirs either.
However it is safety related, so we cannot reiterate it enough!
SKT is online now
post #35 of 111 Old 05-12-2008, 08:33 PM
CJ Chet
Mine is going to be a fancy grab bar for my wife to get in and out!
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #36 of 111 Old 05-12-2008, 09:29 PM
CopperCJ7
My Irish redhead of a wife wants me to install a couple pair of handcuffs on the rollcage for effect!
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #37 of 111 Old 03-02-2009, 09:27 AM
Blthomas
Blthomas's Avatar
1979 CJ7
I bumped this thread as I just swapped out the bar myself in my CJ.
But no one around here carries a nutsert, some don't even know what I'm talking about. Anyone that has these at ACE can get me a stock number or a pic of the package so my ACE guy can get it in?
I've looked at Tractor Supply, ACE, Lowes, no luck.
Thanks
79' CJ7 - 4" lift, 33's
81' CJ8 bone stock
80' Chief "S" 6" lift, 33's
Blthomas is offline
post #38 of 111 Old 03-02-2009, 10:20 AM
VACJ7
VACJ7's Avatar
I ran across this home made nutsert / riv-nut tool a while ago. Have not tried it yet but have a feeling I may when I go to pull my skid next week.
http://www.fjr1300.info/howto/rivnut-tool.html
VACJ7 is offline
post #39 of 111 Old 03-02-2009, 12:00 PM
Jiffy
1983 CJ7
Frame Mounted Roll Bar
I did this swap last summer and now my project is to have someone anchor the YJ bar to the frame. (other than 2 bolts the fiberglass tub is the only thing holding it.) I know Kentrol makes a kit for this, but I was wonder if anyone has pictures of what they did when anchoring it to the frame. Iím just looking for ideas so I can present them to the person I hopefully find to weld on my cage.
Thanks in Advance.
Jiffy is offline
post #40 of 111 Old 03-02-2009, 04:01 PM
Blthomas
Blthomas's Avatar
1979 CJ7
Thats pretty slick. I can't get them anywhere though. We have a Fastenal in town too (new) but they'd have to order them.
81' CJ8 bone stock
Blthomas is offline
post #41 of 111 Old 03-03-2009, 08:42 AM
78CJFIVE
1978 CJ5
Is this possible on a CJ5?
78CJFIVE is offline
post #42 of 111 Old 03-21-2009, 10:54 AM
wavejd
Hi Bard -
Thanks for your quite useful posting about how to retrofit a YJ family cage into a CJ. I have almost finished this project thanks to your good advice (into my '82 CJ-7).
One question I have for you is whether or not you had a problem with the length of the seat belts in the rear. Everything went in fine like in your directions and when I finally climbed in the back to try it out, I could barely get the shoulder/lap belt around my torso (I'm 6'2" / 190 lb so that shouldn't really be the problem). I also tried putting in my kids booster seat in the back. While that was a little better, it was still a tight fit.
I can probably try to rig up something to extend the length of the female end but I am curious to see if you had a similar problem. In your photos, it looks like the belt goes thru the back of the car seat which means you are not likely to see the problem. However, if you put a kid in a booster seat and the belt routing changes, you might have a problem.
Thanks again for your tips.
Jim
wavejd is offline
post #43 of 111 Old 03-25-2009, 09:17 AM
elks96
OK I am checking to see how the soft top issue has went? Has anyone had any issues getting a besttop super top to work with this set up?
Thanks for the input I am sure I will be doing a little modification to get it to work correctly.
1985 CJ 7 258 bored/Cammed, MotorCraft Carb, Mallory Ignition, NP435/Dana 300, 4.5 RE Ex, 1.25 JKS Body Lift, Detriot AMC 20 Rear(detroit locker and Warn Hub Conversion), Herculined Tub, Chevy Heater Blower, 34" Swampers, Custom Rear Bumper, more to come....
1972 K5 8" lift, 36" swampers, lockers, custom paint.
elks96 is offline
post #44 of 111 Old 03-25-2009, 09:20 AM
DT5150
1983 CJ7
no problems with the super top..
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #45 of 111 Old 03-25-2009, 11:54 AM
243
1978 FSJ Cherokee
I specifically asked Bestop if the Wrangler Supertop would work with the YJ Sport Bar in my CJ. They said no problem.
Dave's 78 Build
243 is offline
How Much to give for a Yj Style Rollbar? elks96 Jeep CJ Forum 18 02-23-2009 12:03 PM
Old style rollbar, I need padding PhatBasturd Jeep CJ Forum 1 02-08-2008 11:12 PM
rollbar pad moach1 Jeep CJ Forum 4 10-03-2006 03:54 PM
CJ7 rollbar DEERSLAYER1407 Jeep CJ Forum 5 08-18-2004 08:04 PM
CJ rollbar CJay7 Jeep CJ Forum 6 10-24-2003 08:35 AM
