Changing a CJ rollbar to a YJ family style rollbar - Page 2 - JeepForum.com
post #16 of 111 Old 05-09-2008, 10:42 PM
CopperCJ7
While I think you did a great job, I don't like bolting the bar to the windshield for two reasons. 1) It makes it really tough and time consuming to fold the windshield down. 2) The windshield really isn't structurally rigid. It collapses in a rollover. I went to the dashboard and made the entire front section removable to get behind the dashboard if needed to repair or replace things behind it. With my cage design, I can still fold the windshield down and have the cage for safety. The front loop also has a left-to-right crossmember for added strength.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #17 of 111 Old 05-10-2008, 05:23 AM Thread Starter
Bard
Originally Posted by CopperCJ7 View Post
While I think you did a great job, I don't like bolting the bar to the windshield for two reasons. 1) It makes it really tough and time consuming to fold the windshiled down. 2) The windshield really isn't structurally rigid. It collapses in a rollover. I went to the dashboard and made the entire front section removable to get behind the dashboard if needed to repair or replace things behind it. With my cage design, I can still fold the windshield down and have the cage for safety. The front loop also has a left-to-right crossmember for added strength.
Thanks Copper - I agree with the windshield being easily folded down, but mine stays up most of the time. All it takes to remove the 4 bolts on the nutserts, stock dash screws and 1 main torxs on the sleeves if I really wanted to.
As I alluded to in the very beginning of the write up, this is a straight YJ to CJ change and just adds a new look and works better with the 3 point seatbelts for the rear. As for cage, it is not a cage and shouldn't be looked at that way. there are no frame supports, same as the factory ones. If I wanted to build a cage, I would have. Thanks and nice looking Jeep, some good ideas there.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #18 of 111 Old 05-10-2008, 05:32 AM Thread Starter
Bard
Originally Posted by bigjoe View Post
Nice write up Bard. Question about the rear bar and the front stringers. Are they bolted to the center bar? I want to do this in My '77 but it has the old style "A" bar bolted to the top of the wheel well and the tub has no holes at the bottom of the tub of course, why would it So I was thinking if the YJ bars unbolt I could either weld or bolt them to the factory bar an then attach to the rear of the wheel well and windsheild. Or my other option could be to remove factory bar and them bolt the whole YJ bar in it's place. That would only leave me with the issue of 4 holes on each side of the tub.
Any suggestions?
Hi Joe, Thanks. I would almost pull the A bar out and use the whole YJ bar. I think it would be faster. Not sure if you have lap belts or a 3 point belts for the front seats?
I would just drill 4 holes thru the floor of the tub to attach it. Same with the rear, which would be 2.
I think you are referring to having the 4 holes down the side of the tub where the A bar originally was, correct? You could get some carriage bolts and they would be pretty close to being flush with the tub.
Bard is offline
post #19 of 111 Old 05-10-2008, 06:08 AM
Bubba Ray
Good writeup. Thanks
Bubba Ray is offline
post #20 of 111 Old 05-10-2008, 08:14 AM
bigjoe
1977 CJ7
Heh Bard, Yes I have lap belts up front and as of right now nothing in the back (seat or belts). I like the idea of the carriage bolts. I was thinking of reuseing the torxs that hold the rollbar through the side into the tub. Kind'n mess with the unknowing a little for fun.
Yes I agree the more I think about it that maybe just putting the whole YJ bar in will save a ton of time. Something I never seem to have enough of anyway.
What hardware grade to bolt up the bar, 8, right?
bigjoe is offline
post #21 of 111 Old 05-10-2008, 08:38 AM Thread Starter
Bard
I would use grade 8, stronger than grade 5, costs a little more. All the torx bolts in the belts and rollbar are grade 8. And they drill like grade 8's
You can reuse the torx bolts, I just drilled my old threads out bigger and put bolts in them and I had to make my floor anyways. If you heat them with a torch until cherry red and put an impact on them, they should come right out.
Bard is offline
post #22 of 111 Old 05-10-2008, 09:54 AM
bigjoe
1977 CJ7
Time to take stock in PB Blaster
bigjoe is offline
post #23 of 111 Old 05-10-2008, 01:51 PM
DirtEater
1982 CJ7
As everyone else has said...very good write-up Bard.
I believe my roll bar is the same as yours. Bad thing is it's simply bolted to the windshield with some kind of sheet metal screw and one of them is stripped so it's not very secure and drives me crazy. I've never seen the nutserts before and the whole concept seems kind of weird. Sure would like to see them in person. May have to find an Ace Hardware nearby. I wonder if they have them Home Depot or Lowes. Looks like a great way to securely mount them to the windshield.
Where did you get your roll bar pads from? Can you simply order them from Quadratec for the YJ(92-95?). I can't post pics of mine cuz I can't figure out how from the few pics that are stored on my computer. The "insert image" tab at the top doesn't allow from the computer, unless I'm just a dummy......
Terry ~ USN Ret. 30Sep07 : )
1982 CJ7 4.2L ~ T-999 ~ Dana 300 ~ SOA Conversion
Dana 30/AMC 20 with Truetrac - one piece axle - 4.10's
33" Toyo M/T's on Pro Comp Xtreme Series 1069
Borla header and Catback Exhaust System
Jeeperman bumper w/ Ramsey Patriot 8000 - Jeeperman tire carrier/bumper
DirtEater is offline
post #24 of 111 Old 05-10-2008, 02:26 PM
bigjoe
1977 CJ7
To post images make yourself a photobucket acct. and put yout pics there then use the image link to cut and paste them to forum.
bigjoe is offline
post #25 of 111 Old 05-10-2008, 03:28 PM
CopperCJ7
If you really want to get fancy, you can use stainless "ARP" bolts - which are grade 8 but have a pan head.
post #26 of 111 Old 05-10-2008, 04:43 PM Thread Starter
Bard
Hi, thanks, Yes nutserts would fix it. I am sure Home depot or Lowes might have them. You can even go on line to any of those stores. Any hardware store might have them. Ace is local for me. Rollbar pads came with it. I will take a look and see what they are.
Bard is offline
post #27 of 111 Old 05-10-2008, 06:07 PM
CjinPA
CjinPA's Avatar
Quadratec, 4wd.com, ebay all have the roll bar pad for sale. If you switch to a family style cage like Bard you will need to buy the roll bar pads for a 92 to 95 YJ. I bought mine new off of ebay for $50.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #28 of 111 Old 05-11-2008, 02:44 AM
SKT
Great write-up, especially for folks who don't weld their own stuff, and/or don't want to spend a lot on a custom cage!
Looks great!
SKT is offline
post #29 of 111 Old 05-12-2008, 01:40 PM
*Thunder
1979 CJ7
I live in southern Indiana and nobody had heard of nutserts (or rivnuts), not even my freindly Ace Hardware. Lowes and Home Depot definately didn't know what I was talking about. I eventually ordered some from Fastenal. I bought a riveter from Harbor Freight tools for $15-20 bucks, but it only sets the smaller nutserts. It actually came with 3 or 4 different sizes. Fastenal had the larger riveter, but it costs around $100.00. I can't see paying that with so many other things I want to do.
Where did you get the nusert tool you used?
*Thunder is offline
post #30 of 111 Old 05-12-2008, 03:05 PM Thread Starter
Bard
hmm,, might be location, my store seems to have everything. I will ask if they are ACE or someone else. I think I pay $2.10 per nutsert, the tool is like $3.40 or $4.20 and the bolts are what they costs. I go there atleast 3 times a week for something. I could do a package deal and mail them if you want. PM me if you want me to.
Bard is offline
How Much to give for a Yj Style Rollbar? elks96 Jeep CJ Forum 18 02-23-2009 12:03 PM
Old style rollbar, I need padding PhatBasturd Jeep CJ Forum 1 02-08-2008 11:12 PM
rollbar pad moach1 Jeep CJ Forum 4 10-03-2006 03:54 PM
CJ7 rollbar DEERSLAYER1407 Jeep CJ Forum 5 08-18-2004 08:04 PM
CJ rollbar CJay7 Jeep CJ Forum 6 10-24-2003 08:35 AM
