Changing Changing AMC 20 2.73 to 3.73 - advice on carrier change out? - JeepForum.com
post #1 of 4 Old 05-02-2013, 12:23 AM Thread Starter
Colt44
1983 CJ7
It would seem that I'll need a "3.07 or greater" carrier in order to change the gearing on my AMC 20. My understanding is that "carrier" is the same as "differential" in terms of ordering the part. Question is, will I have to buy the whole carrier with all the parts, or can I get the bare diff and move the guts over?
Alternatively, what if I wanted to take the opportunity to install a PowerTrax?
Please help me get my head around this...
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #2 of 4 Old 05-02-2013, 05:12 AM
keith460
Jeep. There's Only One
keith460's Avatar
You only need to purchase a bare carrier case with no internals. You move all the spider gears, thrust washers and pin from the old carrier case to the new one. As for the option of purchasing a Powertrax unit, that only requires removing the spider gears, thrust washers and pin and putting that unit in place of. They are considered the 'lunchbox" type posi units which requires no removal of the original carrier case, everything stays where it is.
Dana 30 axles require new carrier case when using gear range from 3:07-3:54 and a another for 3:73-5:38
AMC 20 axles require new carrier case when using gear range from 3:07-5:38
Example: My factory gears were 3:31 and I changed them to 4:10's. I only needed to purchased a new front Dana 30 carrier to do the swap.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 4 Old 05-02-2013, 11:06 AM
Renegade82
1982 CJ7
I agree with Keith. I did this same change back in the mid 90's. New carriers, new gears (R&P), new bearings, shims, and seals. But I had bought a rear TrakLok carrier with all the guts.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #4 of 4 Old 05-02-2013, 11:55 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Keith,
Boy, how some pics would help to get my head around this post.
hint hint....
Matt
Matt1981CJ7 is offline
