Change from Automatic to Manual - JeepForum.com
post #1 of 12 Old 03-11-2010, 06:01 PM Thread Starter
DeVo24
I'm trying to not get to psyched but I finally found a jeep I can afford to start with. The only fall back is it's an automatic, but the transmission is shot and needs to be replaced anyway. How hard is it to change one of these from an automatic to a manual?
DeVo24 is offline
post #2 of 12 Old 03-11-2010, 06:31 PM Thread Starter
DeVo24
I may have worded that poorly, what I meant was how much hacking and cutting should I expect if any. My assumption would be it would mostly be a bolt in change with the addition of the parts needed for the change. What I'm wondering is will it require any changes to the frame, major cutting on the tub?
DeVo24 is offline
post #3 of 12 Old 03-11-2010, 06:40 PM
crazyeye
1979 CJ7
The easiest way to do it is find a parts jeep. That is all rotted out . All your parts are there for the exchange. No changes to the frame. The only thing is that the transmission hump needs to be cut out or swapped from another jeep.
crazyeye is offline
post #4 of 12 Old 03-11-2010, 06:42 PM Thread Starter
DeVo24
I assumed it would be something like that, thanks for the heads up. Now I can begin obsessing.
DeVo24 is offline
post #5 of 12 Old 03-11-2010, 08:20 PM
John N
1981 CJ8
Another way to do this, if it's a 1980 to '86 with a TF999, plenty of people decide to do the reverse. Be patient, find someone who wants an automatic and trade parts. That way both of you get everything you need.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #6 of 12 Old 03-12-2010, 08:03 AM
Oily
Are you sure about this ? I had an 83 CJ7, 258/T5 and now have an 85 CJ7, 258/auto. I had both for a short time and did comparisons. I never noticed that. I think the shifter floor plate cover is all that needs to be swapped. The automatic has column shift and only a floor shifter for four wheel drive selection. A bolt in replacement.
Oily is offline
post #7 of 12 Old 03-12-2010, 09:01 PM
crazyeye
1979 CJ7
Ya thats what i meant sorry. I did a swap about 10years ago from auto to stick. Swapped a t18 tranny and transfer case in my 82cj7 that i had
crazyeye is offline
post #8 of 12 Old 03-14-2010, 07:32 PM
justjeeps
I do not have the manual tranny, but I have the brake/clutch pedal assembly, steering column, tranny tunnel cover, and assorted other parts if you'd be interested in a trade. What year CJ do you have?
justjeeps is offline
post #9 of 12 Old 03-15-2010, 05:46 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
As replied, the most cost efficient method is to find a similar year CJ with the manual transmission you want. 76-79 there were only two: T150 and T18 with the Dana 20 transfer case. 80-86 there were: SR4/T4, T5, and T176 options all with the Dana 300 transfer case.
Biggest PITA? Probably installing the hanging pedal assembly which will require removal of the steering column, and a bunch of under dash contortions.
Personally, I would do some soul searching and determine what the CJ purpose is. Daily driving, or commuting in stop and go traffic, would certainly make that automatic an asset.
"In the end...It's all Hack."
HackFabrication is offline
post #10 of 12 Old 03-15-2010, 07:31 PM Thread Starter
DeVo24
`I actually haven't bought one yet. But I have a few I'm looking at over the next week and they all seem to be automatics. I absolutely hate automatic transmissions in just about any vehicle. If it was between an automatic or no jeep I'd just have to live with the auto, I was just curious how hard it would be to swap out later.
DeVo24 is offline
post #11 of 12 Old 03-29-2010, 09:26 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Take your time looking and start out with the vehicle configuration you really want in the first place. You will be much happier.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #12 of 12 Old 03-30-2010, 04:33 AM
243
1978 FSJ Cherokee
^^^ that is great advice!
Dave's 78 Build
243 is offline
Automatic Column in Manual CJ? Hybrid Jeep Jeep CJ Forum 3 12-04-2009 10:57 PM
cj-7 manual or automatic psbeaman Jeep CJ Forum 17 06-17-2009 02:52 PM
Swap Automatic For Manual Davey4000 Jeep CJ Forum 0 05-13-2006 06:20 AM
Automatic to Manual tranny? TrappG Jeep CJ Forum 6 09-15-2003 11:09 AM
manual to automatic jeephandyman Jeep CJ Forum 3 10-04-2002 11:27 AM
