center spring bolt - JeepForum.com
post #1 of 4 Old 09-30-2002, 01:51 PM Thread Starter
rustyCJ
center spring bolt
I broke the center bolt on my rear spring pack. So far the only way I have found to buy a new one is with an add-a-leaf. Is that bolt a hardened bolt? Can't I just use a regular bolt. The spring pack is held togther by the spring perch and plate right? the only thing the bolt really does is keep the spring together when not on the vehicle and keeps it on the perch when it is on the vehicle. Maybe I am wrong. I am sure somewhere down the road someone has come into this to so, any information or suggesitons would be great.
b.t.w. - I have no idea what these spring came off of. The guy I got them from said they were from a wagoneer but he wasnt positive bout that. they are the same length as stock CJ springs but have 7 and 8 leafs per pack and lift my jeep around 2.5". Anyone know what they came from?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #2 of 4 Old 09-30-2002, 04:31 PM
jadams68
jadams68's Avatar
Go to a junkyard...any old pick n' pull yard... find their CJ section and snag a couple from an old beater...
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 4 Old 09-30-2002, 05:10 PM
CSP
My local NAPA store carries center pins. They have a wide selection to pick from.
CSP is offline
post #4 of 4 Old 09-30-2002, 11:25 PM Thread Starter
rustyCJ
CJ section in a junkyard? Jeep parts around here are hard to come by. There are bout 15 salvage yards and not a single one of them has a CJ or wrangler in it if that tells you anything.
Center pin? so thats what it is called. I will give Napa a call tomorrow.
So I cant just take a grade 8 bolt and grind the head down so it fits in the spring perch?
rustyCJ is offline
leaf spring bolt semaJ Jeep CJ Forum 9 12-07-2009 05:12 PM
torx bolt w/ center pin StewartCJ7 Jeep CJ Forum 6 10-15-2009 02:03 PM
Can't get bolt out of leaf spring GraKee99 Jeep CJ Forum 24 09-26-2009 09:33 PM
chevy 10 bolt and spring over dgsmith50 Jeep CJ Forum 1 10-01-2007 08:48 PM
Spring Eye Bolt twmattox Jeep CJ Forum 9 01-24-2007 08:46 AM
