Caster, Steering - JeepForum.com
post #1 of 16 Old 05-11-2012, 08:13 PM Thread Starter
gary4569
Caster, Steering
1984 CJ7 Laredo, all stock suspension. No lift. Power steering.
The problem I am having is: Caster angle?
1. Steering does not return to center after turn.
2. Very easy to steer.
3. Can easily oversteer if not careful. Maybe a little surge when turning.
I have replaced leaf spring bushings.
Ball joints and tie rods ends appear to be in good shape. No play
Wheel bearings- No play
Caster angle 4deg
With all stock and no play in any of the steering components. How could caster angle be off?
I have read that the PS pump flow control valve can cause some of the problems I am having. What are the chances it could be the PS pump?
Thanks in advance
gary4569 is offline
post #2 of 16 Old 05-11-2012, 08:27 PM
GlennLever
GlennLever's Avatar
Caster angle 4deg
Thanks in advance
Caster should be 6 degrees.
Even at six degrees mine still does not completely return. I'm thinking of going to seven
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #3 of 16 Old 05-11-2012, 09:32 PM
gojeepin
1983 CJ7
1984 CJ7 Laredo, all stock suspension. No lift. Power steering... With all stock and no play in any of the steering components. How could caster angle be off?
The springs can bend over time... especially the front. Read the article linked in my signature block. I show an illustration.
... I have read that the PS pump flow control valve can cause some of the problems I am having. What are the chances it could be the PS pump?
Only if it impedes the steering movement. Since you say it's very easy to steer, I don't think that's a high probability. However, if your caster angle is good, continue with that line of thought.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 16 Old 05-11-2012, 10:54 PM
7179CJ5
1979 CJ5
hey GlennLever, i see that you have 2.5 old man emu lift, what did you do to correct your caster in your before and after measurments?
7179CJ5 is offline
post #5 of 16 Old 05-12-2012, 10:17 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Caster angle 4deg
So, How did you come to the conclusion your caster is out of spec ?
What are the exact specs of caster for both sides ?
Your symptoms sound like the steering/gear box is too tight.
LT1CJ7 is offline
post #6 of 16 Old 05-12-2012, 12:42 PM
TIPPEDITOVER
At the Mall
TIPPEDITOVER's Avatar
1978 CJ5
Your symptoms sound like it's a CJ haha. Mine has always behaved somewhat like you describe. When I took delivery of my CJ 2 yrs ago it had nearly 0 deg caster and it required constant and immediate steering input at all times you were moving. The slightest imperfection in the road would send it in another direction. First thing I did was roll those knuckles back 5 deg and now most of that has disappeared. Still has just a little, but it's a lifted CJ so I cut it some slack.
TIPPEDITOVER is online now
post #7 of 16 Old 05-12-2012, 12:48 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
My KISS theory says, look at tire pressure. Ok, but I'm cheap when it come to T-shooting. Just 'cuz it says max pressure 44 psi, doesn't mean that 35 isn't ok. Most of our tires are for 1/2 ton trucks. Not little CJs.
My 2 cents.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #8 of 16 Old 05-12-2012, 01:19 PM
GlennLever
GlennLever's Avatar
Four degree wedges
Glenn R. Lever
My Web Site
post #9 of 16 Old 05-12-2012, 09:41 PM Thread Starter
gary4569
I have not came to a definite conclusion that is caster. That just seems like the most likely cause based on the symptoms. I have not been to the alignment shop for exact caster measurements. Took measurements w/ ipod level app. Not sure if that is very accurate.
How would I check for steering box too tight. Loosen the set screw on top?
gm
gary4569 is offline
post #10 of 16 Old 05-12-2012, 09:47 PM Thread Starter
gary4569
My 2 cents.
Have tried different pressures, with best results around 30psi.
gm
gary4569 is offline
post #11 of 16 Old 05-12-2012, 09:48 PM
GlennLever
GlennLever's Avatar
Try jacking the front tires off the ground, pull on the leading edge of one tire and push on the trailing edge of the same tire and you should be able to turn the wheel and tire assemble with some effort.
Glenn R. Lever
My Web Site
post #12 of 16 Old 05-12-2012, 10:06 PM Thread Starter
gary4569
I will try that...
If I can not turn, steering box too tight?
gary4569 is offline
post #13 of 16 Old 10-23-2013, 06:08 PM Thread Starter
gary4569
Problem solved
UPDATE
Both bottom ball joints were very tight.. Service manual specifies that turning force should be less than 10ft/lbs per side with tie rods disconnected. i had close to 20-25 per side. With new ball joints, turning force is now ~7lbs per side.
She now returns to center and drives straight!!!
Gary M.
gary4569 is offline
post #14 of 16 Old 10-23-2013, 06:18 PM
keith460
Jeep. There's Only One
keith460's Avatar
I had that same problem on the Jeep before, long time ago, bottom ball joints tight. Basically both were rusted and made the Jeep wonder until replaced with new ones.
1984 CJ-7 Renegade
keith460 is offline
post #15 of 16 Old 10-23-2013, 11:47 PM
82JeepCJ7
1982 CJ7
I've seen the same symptoms with the toe in/out being way off.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
caster , steering
Caster. CoAce Jeep CJ Forum 5 02-13-2012 01:53 PM
Steering wander-caster/torque steer/etc jsthompson Jeep CJ Forum 13 07-16-2011 07:44 AM
Help with Caster Beach-Head Jeep CJ Forum 29 02-17-2011 08:39 PM
Caster angle and no return to center with steering wheel I6CJ7 Jeep CJ Forum 19 05-10-2010 10:15 AM
I hate to start a loose steering thread, but caster is spot on? SpencerC Jeep CJ Forum 25 08-05-2009 04:46 PM
