Caster angle question - JeepForum.com
post #1 of 9 Old 01-23-2007, 12:21 AM Thread Starter
jode
Is this an accurate way to measure caster?
If it is, then I have a problem. it is hard to see in the pics, but it is registering 1.75-2.5 degrees of caster (give or take a degree or two.)
Also, for those of you that have played around with shackle length, is there any kind of estimation on how many degrees of caster are added/subtracted per inch of change to the shackle length? I'm trying to figure out if I reduce my shackles by an inch or two, how much that will affect my caster.
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #2 of 9 Old 01-23-2007, 04:49 AM
iengle
Accurate? No, but a decent way to get a starting point. You really need to know the angle from ball joint to ball joint -- if there are any caster sleeves in the upper, you can't measure that from the outside of the inner C.
Bring out the old geometry skills and I'm sure you can figure out the change in caster by length of shackle. But, the best suggestion is going to be to go with the shortest shackle as possible and get your lift by a better route (spring, SOA, etc.).
Iz
iengle is offline
post #3 of 9 Old 01-23-2007, 05:01 AM
CJ51973
CJ51973's Avatar
That is probably OK what your showing. I typically go with the bottom ball joint. You'll need to take the zerk out to do it.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #4 of 9 Old 01-23-2007, 09:17 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
There is some great info here:
http://extremegarage.com/techtips/stechtip.htm
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #5 of 9 Old 01-23-2007, 10:25 AM Thread Starter
jode
You are correct...like this for instance:
The reason we have an offset angle between upper and lower spindle points is to allow optimum steering and handling for a given vehicle. A positive caster angle is used to allow predictable steering of the vehicle. If the caster was zero with the upper ball joint exactly above the lower ball joint, steering would be erratic, the vehicle would be very hard to control and the front wheels would wander all over the road. By creating a backward 'lean' (a positive caster angle), the vertical travel of the front wheels is 'dampened.' The more positive the caster angle, the more controllable the vehicle is at higher speeds. As caster is lessened (closer to zero), the vehicle's front wheels will react faster to steering input, but highway stability will be decreased.
But that isn't really pertinent to the question of the best way to measure caster when the axle is assembled and you can't get to the balljoints....
jode is offline
post #6 of 9 Old 01-23-2007, 03:10 PM
jeepin in maine
any variance in the width of the knuckle from top to bottom will throw your reading off.best way is to pull a zerk fitting and put your angle finder on the top or bottom balljoint
jeepin in maine is offline
post #7 of 9 Old 01-23-2007, 03:19 PM Thread Starter
jode
I'll do that - thanks.
jode is offline
post #8 of 9 Old 01-23-2007, 04:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I want to say the top part of the "C" is a little narrower than the bottom so that's gonna throw you off a bit. Like mentioned already, go from the flat on the bottom ball joint....
BESRK is offline
post #9 of 9 Old 01-23-2007, 04:41 PM Thread Starter
jode
If anything, then, yes, the top would be more narrow....which means I may be running closer to zero caster. No wonder it wanders all over the road...
jode is offline
How do measure caster angle? scarlett Jeep CJ Forum 3 05-23-2009 05:40 AM
Another Caster angle questions Dad03 Jeep CJ Forum 1 02-23-2009 06:43 PM
caster angle questions (I read the sticky) Kingair Pilot Jeep CJ Forum 5 05-06-2008 07:08 AM
caster angle ? drunkenrich Jeep CJ Forum 2 02-11-2008 07:13 AM
Checking caster angle... 79cj7reny Jeep CJ Forum 5 11-24-2007 07:14 PM
