Caster - JeepForum.com
post #1 of 9 Old 03-12-2010, 06:18 PM Thread Starter
78orangejeeper
1978 CJ7
Caster
Does anyone have a picture of the axle with the correct caster angle with or without wedges? I am having a hard time visulizing this? I am having some of the same wandering issues while driving. The PO put a new steering box before I purchased. since, I have replaced the steering shaft which was completely worn out. It has a 2 1/2 in suspension lift so I think it may be a caster alignment issue. Thanks for the help.
78orangejeeper is offline
post #2 of 9 Old 03-12-2010, 06:19 PM
alex211
1995 XJ Cherokee
Are the shackle stock length or longer? The only real way to measure caster is with an angle finder on the knuckles.
95 xj bone stock for now
alex211 is offline
post #3 of 9 Old 03-12-2010, 06:31 PM Thread Starter
78orangejeeper
1978 CJ7
Stock shackles
post #4 of 9 Old 03-12-2010, 06:42 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Well, The ONLY REAL way to get a correct caster measurment is an alignment.
An angle finder will get you in the ballpark, If done correctly.
LT1CJ7 is offline
post #5 of 9 Old 03-15-2010, 08:32 AM
CSP
Even if you had a picture it's not like the difference will be visible.
CSP is offline
post #6 of 9 Old 03-15-2010, 10:09 AM
Skotter
Do a search for "castor" and there's a comprehensive write up on it (might even be sticky, not sure). I'd stay away from shims. Generally, they're either going to negatively affect your castor or your pinion angle. Might help one, but it's going to hurt the other.
Skotter is offline
post #7 of 9 Old 03-15-2010, 10:35 AM
80cj
80cj's Avatar
1980 CJ5
That's true especially when you consider that stock caster agnle from the factory is 3 degress +1 (4 degrees?). Mine was only 2 degrees and I added in 4 degree steel shims for a total of 6 degrees positive. Drives and handles excellently. As you say, the compromise is in the front U joint angle but I normally run with my hubs free anyway and seldom exceed 20 MPH in 4WD. I run a 2" lift with my skid plate lowered 5/8" to correct rear U joint angles. I've noticed that with this setup, there is a barely noticeable angle at the front pinion U joint. If I really wanted to run with my front hubs locked on the highway, a CV joint could be used at the transfer case front output assuming that there is enough room at the skid plate to accomodate the bulk of the CV .
80cj is offline
post #8 of 9 Old 03-29-2010, 09:11 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Do a search for "caster" and you'll have even better results.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #9 of 9 Old 03-30-2010, 08:00 AM
Skotter
Thanks PP, it's all in the little details, like proper spelling.
Skotter is offline
SOA Caster Adjustment Marinehorne Jeep CJ Forum 0 11-10-2009 04:02 PM
Caster Shims nd4spdbh Jeep CJ Forum 14 07-14-2008 12:28 PM
Caster problem? 79cj7reny Jeep CJ Forum 1 05-28-2007 10:30 PM
Measuring the Caster caxmach Jeep CJ Forum 10 02-12-2007 04:25 PM
Caster Shims Blue83CJ7 Jeep CJ Forum 2 09-29-2006 07:52 AM
