Carter YF did not have discharge ball or weight - JeepForum.com
post #1 of 8 Old 01-17-2010, 07:52 PM Thread Starter
bprimrose
1978 CJ5
I just rebuilt a Carter YF from a 1978 CJ5 258. There was no discharge ball or weight. So...I just put it back together. Now the motor stalls chokes and runs rough until it warms up. But it didn't do that before the rebuild. SHould I pull the Carb and find a weight and Ball?
Thanks
bprimrose is offline
post #2 of 8 Old 01-18-2010, 02:13 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Did you get a rebuild kit? They usually have them included.
But that may not be the problem. There may be other problems with re-adjusting the carb or in rebuilding.
John Strenk is online now
post #3 of 8 Old 01-18-2010, 04:21 AM Thread Starter
bprimrose
1978 CJ5
ball and weight
John,
Thanks for the reply.
There was a ball but no weight in the rebuild kit.
I used the Jeep service manual for adjustments. What adjustment could I need to make. I really am an amateur.
The Jeep starts great, Idles high, but runs well. THen when you give it gas it bucks and sputters and stalls without feathering the gas. If you try to drive it it does the same thing. However, after warmup it runs great smooth?
Thanks
Brian
post #4 of 8 Old 01-18-2010, 04:42 AM
John Strenk
1976 CJ5
What type of choke do you have on it. Automatic or manual. Are you sure the choke closes properly?
Also When adjusting the metering needle, did you push down on the pump as shown before adjusting the screw? I've made this mistake before.
post #5 of 8 Old 01-18-2010, 04:47 AM Thread Starter
bprimrose
1978 CJ5
Automatic, heat activated. MAybe a dumb question but, Any special way to adjust choke closing other than to look?
I did push down on the pump before adjusting the screw. This was a first for me. So I could have done anything!!
post #6 of 8 Old 01-18-2010, 05:12 AM
John Strenk
1976 CJ5
Well there is a procedure but for me, when the engine is cold I just adjust the cover until the choke valve is fully shut.
Here is the procedure.
post #7 of 8 Old 01-18-2010, 10:03 AM Thread Starter
bprimrose
1978 CJ5
carb problem continues
Well, it just goes on.
Again, this is from a complete newbie.
Per your advise, I checked the choke valve when cold and it was closed all the way. However on starting it opens 1/2 to 3/4s.
Spits and sputters when I try to give it gas or accelerate. When warm, it runs fine.
I appreciate any feedback on this issue!!
post #8 of 8 Old 01-18-2010, 10:45 AM
John Strenk
1976 CJ5
Well a simple test would be to rotate the choke cover a couple of degrees richer. This delays the opening of the choke a little longer. The choke should open a little when the engine starts. There is a piston in the choke housing that when vacuum is applied as when the engine starts will pull the choke open so you don't kill and flood the engine.
Also don't overlook how well your ignition is working either. A good strong spark will help fire off a cold mixture.
Looks like the choke should only open around 1/4" at startup.
AMC V8 Multiple Spark Discharge systems? sbcranger Jeep CJ Forum 27 03-03-2010 01:15 PM
Carter BBD Help doeboy99 Jeep CJ Forum 19 10-12-2008 03:13 PM
hei and carter ? damian H Jeep CJ Forum 1 11-03-2006 07:06 AM
ball joint shims or adj ball joints? jm708 Jeep CJ Forum 9 10-26-2005 09:45 AM
Carter VS. Mc Smalls Jeep CJ Forum 1 04-09-2003 08:46 PM
