Carter YF carb problem (maybe or maybe not) - JeepForum.com
post #1 of 2 Old 08-08-2008, 12:24 PM Thread Starter
pnorris
1976 CJ7
I just installed a new remanufactored Carter carb mainly because you had to pump and pump the gas pedal to get it to start after it sits for a day or so. and it was started to run a little sluggish. I put the new carb on and a big difference in the performance, but I still have to pump the pedal after it sits for awhile. My question is on the fuel filter I know the smaller of the two outlet spouts suppose to be on the top. But does the intire filter need to be above the float bowl of the carb? Mine fuel filter is lower than the float bowl. I'm wondering if gas can still siphon back thru the small line in the fuel filter?
Where is the gas going?
pnorris is offline
post #2 of 2 Old 08-08-2008, 12:44 PM
Mike Romain
Interesting....
The stock placement of the fuel filter is above the float bowl....
A pinhole leak in the suction line from the tank to the pump can also cause it to empty out when it sits. these leaks at first only show as stains because it is a suction line. The rubber lines at either end or the clips where the steel line hooks tot he frame are the suspect spots.
A bad backflow valve in the pump can also cause this. To test, get it running, then shut it down and unhook the line where it goes into the pump. Only a little should come out, if a whole bunch comes out, that could be the trouble.
Mike
Mike Romain is offline
Carter BBD Carb.-Choke Problem! PICS Rocket6R Jeep CJ Forum 21 06-14-2013 01:05 PM
'72 CJ5 - 232 w/ Carter YF Carb 1972-CJ5 Jeep CJ Forum 2 11-23-2009 07:44 AM
Carter YF Carb Problem swann145 Jeep CJ Forum 7 07-02-2009 08:47 AM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
