Carter YF Carb Problem - JeepForum.com
post #1 of 8 Old 06-30-2009, 01:34 PM Thread Starter
swann145
1978 CJ7
I am having problems with my accelerator pedal not returning to the regular position when I take my foot off the gas. I think I have narrowed the problem down to something with my carb, but I am not sure what to do now. It seems like a spring or something isn't pulling the accelerator cable back to the original position. Has anyone else run across this and if so, is there an easy fix? Thanks.
swann145 is offline
post #2 of 8 Old 06-30-2009, 03:27 PM
new cal shooter
1978 CJ5
I just got my cj5 same problem,
Anything you find out please let me know!!
This is my "quick" fix, just an gas pedal return spring about 3" long works, but not "correct" but works fine, i have an extra just in case
This bar is where the pedal and the carb link up to work, this just holds the pedal "IN" so when you let it go, it springs back to close the carb.
new cal shooter is offline
post #3 of 8 Old 06-30-2009, 03:48 PM
semikrazy
1977 CJ7
Maybe a bad throttle cable. My '75 did that so I put a return spring then it was too much for the cable and it snapped, Had to drive from Southern Cal to Pheonix using a string running from the carb to the inside of the jeep so I could pull the throttle open.
semikrazy is offline
post #4 of 8 Old 06-30-2009, 03:51 PM
new cal shooter
1978 CJ5
New cable it is! Autozone here i come!
post #5 of 8 Old 07-01-2009, 10:54 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Originally Posted by semikrazy View Post
Maybe a bad throttle cable. My '75 did that so I put a return spring then it was too much for the cable and it snapped, Had to drive from Southern Cal to Phoenix using a string running from the carb to the inside of the jeep so I could pull the throttle open.
At least I'm not the only one that's done that - My F150 did it to me, at least the (ex)wife was there to shift for me while I'd steer and run the throttle.. Needed a 3rd hand sometimes.. lol
Rick
Cutlass327 is offline
post #6 of 8 Old 07-01-2009, 10:28 PM
new cal shooter
1978 CJ5
so anyone have a real answer for where the throttle cable return spring should be? I have a new cable, no spring came with it
post #7 of 8 Old 07-02-2009, 05:03 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Mine mounts like this:
Look for the high lighted circle.
It mounts on one of the mounting boplts and goes to the throttle lever.
I've seen them mounted in the opposite direction also
John Strenk is offline
post #8 of 8 Old 07-02-2009, 08:47 AM
new cal shooter
1978 CJ5
Is that how is should be from the factory? Or do we all just having to rig it? Thanks!
Carter BBD Carb.-Choke Problem! PICS Rocket6R Jeep CJ Forum 21 06-14-2013 01:05 PM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
Carter YF carb problem (maybe or maybe not) pnorris Jeep CJ Forum 1 08-08-2008 12:44 PM
Carter carb id collinpyle Jeep CJ Forum 9 11-21-2006 01:31 PM
