Quantcast Carter Carb Help----Carb Guru's - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Carter Carb Help----Carb Guru's
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 04-28-2009, 04:48 PM   #1
Goody1231979
1980 CJ7
Hey guys,
Heres the deal, i have a rebuilt engine I am trying to get started. I ve got the timing close. The engine will start and die quickly after. Runs good if the choke is held down but once i take the choke off it dies.
What do you think is the problem?
Should i be looking for a rebuild kit?
Goody
1980 Cj7 on 33's
258 I6
rust...well lots of rust and a oil leak
Goody1231979 is offline   Reply With Quote
Old 04-28-2009, 04:51 PM   #2
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I would suspect the empty lines kicked off enough rust to plug the gas filter. Been there, done that.
Oh, be sure you put the filter in right side up, the center outlet goes to the carb and the top outlet goes to the return line.
And a $20.00 carb kit will do it wonders usually, they (all carbs) are supposed to get a kit every major tune up or when you need plugs. Most are badly neglected...
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 04-28-2009, 05:10 PM   #3
Goody1231979
1980 CJ7
ok i was just talking with my neighbor and hes thinks it something with the vaccuum
1980 Cj7 on 33's
258 I6
Old 04-28-2009, 06:59 PM   #4
Mike Romain
Off Road Forever
Well, I went through a few gas filters when I first started up a system that sat empty for a year and the tank was plastic, so it was just rust from the lines.
I even keep a spare gas filter under the seat because I off road and dirt collects behind the gas cap so some always falls in when I fill it.
A cheap fix if that's it.
A vacuum leak usually makes for high revs...
Mike
Old 04-28-2009, 07:03 PM   #5
Fjguercio
1978 CJ7
Originally Posted by Goody1231979 View Post
Hey guys,
Goody,
This is very important time in the engines life. This is time the engine and cam need to be broken in and ran. Not sure what your problem is but no one has put this bit of caution up yet. Even if you have to put a carb that your know runs on a 258 it better than messing up your new engine build
Fred
Fjguercio is offline   Reply With Quote
Glock Forum
