Carter Carb Help----Carb Guru's - JeepForum.com
post #1 of 5 Old 04-28-2009, 03:48 PM Thread Starter
Goody1231979
Hey guys,
Heres the deal, i have a rebuilt engine I am trying to get started. I ve got the timing close. The engine will start and die quickly after. Runs good if the choke is held down but once i take the choke off it dies.
What do you think is the problem?
Should i be looking for a rebuild kit?
Goody
1980 Cj7 on 33's
258 I6
rust...well lots of rust and a oil leak
Goody1231979 is offline
post #2 of 5 Old 04-28-2009, 03:51 PM
Mike Romain
I would suspect the empty lines kicked off enough rust to plug the gas filter. Been there, done that.
Oh, be sure you put the filter in right side up, the center outlet goes to the carb and the top outlet goes to the return line.
And a $20.00 carb kit will do it wonders usually, they (all carbs) are supposed to get a kit every major tune up or when you need plugs. Most are badly neglected...
Mike
Mike Romain is offline
post #3 of 5 Old 04-28-2009, 04:10 PM Thread Starter
Goody1231979
ok i was just talking with my neighbor and hes thinks it something with the vaccuum
1980 Cj7 on 33's
258 I6
post #4 of 5 Old 04-28-2009, 05:59 PM
Mike Romain
Well, I went through a few gas filters when I first started up a system that sat empty for a year and the tank was plastic, so it was just rust from the lines.
I even keep a spare gas filter under the seat because I off road and dirt collects behind the gas cap so some always falls in when I fill it.
A cheap fix if that's it.
A vacuum leak usually makes for high revs...
Mike
post #5 of 5 Old 04-28-2009, 06:03 PM
Fjguercio
1978 CJ7
Originally Posted by Goody1231979 View Post
Hey guys,
Goody,
This is very important time in the engines life. This is time the engine and cam need to be broken in and ran. Not sure what your problem is but no one has put this bit of caution up yet. Even if you have to put a carb that your know runs on a 258 it better than messing up your new engine build
Fred
Fjguercio is offline
'72 CJ5 - 232 w/ Carter YF Carb 1972-CJ5 Jeep CJ Forum 2 11-23-2009 07:44 AM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
carter carb DonAltman3 Jeep CJ Forum 4 04-28-2008 07:34 PM
Carter YF Carb solitudetree Jeep CJ Forum 4 07-05-2007 05:13 AM
Carter BBD Carb ClarkGriswold Jeep CJ Forum 17 09-06-2006 10:21 AM
