Carter BBD rebuild: Does it matter which rebuild kit I use? - JeepForum.com
post #1 of 3 Old 06-14-2010, 06:16 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
When rebuilding a Carter BBD, does it matter which rebuild kit I use, as long as it's designed for a BBD? Or do I need to match the kit to my specific sub-model of BBD based on markings seen on the carb? Also, does it matter which brand of kit I use?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #2 of 3 Old 06-14-2010, 07:45 AM
86cj74.2L
86cj74.2L's Avatar
if the metal tag is still on the bolt use that number, if not there go by what model it came off of.
86cj74.2L is offline
post #3 of 3 Old 06-14-2010, 11:01 AM
foggybottombob
I think you should pay attention to the spacer with the kit. The kit I bought from NAPA had a laminated cardboard spacer. I decided not to use that and kept the old one I already had. I can't believe someone would give you a 3/4" thick chunk of cardboard to use as a spacer where gasoline was passing through. Sheesh.
foggybottombob is offline
Carter BBD Rebuild - need some reassurance g-love Jeep CJ Forum 11 08-25-2009 05:07 PM
Rebuild Carter AFB or go different? danheit Jeep CJ Forum 0 02-14-2009 01:44 PM
Carter YFA rebuild kit - where to buy? Travisrp Jeep CJ Forum 2 03-15-2008 07:44 AM
77 CJ5 Carter 2681 rebuild kit nickgbb Jeep CJ Forum 1 03-04-2008 09:04 PM
Carter BBD rebuild firebeater Jeep CJ Forum 6 06-14-2001 05:19 PM
