Carter BBD rebuild - Page 3 - JeepForum.com
post #31 of 151 Old 02-24-2014, 08:03 PM
LumpyGrits
The gasket will seal that area.
Never seen those little round seals before......
BTW-The FSM was wrong with the location to measure the piston gap. Your rebuild kit has it 'rite'.
IIRC-There was a service bulletin issued over that error.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #32 of 151 Old 02-24-2014, 08:21 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by LumpyGrits
The gasket will seal that area. Never seen those little round seals before...... BTW-The FSM was wrong with the location to measure the piston gap. Your rebuild kit has it 'rite'. IIRC-There was a service bulletin issued over that error. LG
That's good to know.
86cj74.2L is offline
post #33 of 151 Old 02-24-2014, 08:26 PM Thread Starter
moto450r
Oh boy, well it's easy to adjust. I think I'm going to use the install kits measurement, for some reason it looks like its correct.
Thanks LG
BORN 196# - DIED 20##
Currently living thru the DASH in the middle
moto450r is offline
post #34 of 151 Old 02-24-2014, 08:37 PM
LumpyGrits
Use a wire spark plug gap gauge, to set that gap.
LG
post #35 of 151 Old 02-24-2014, 08:42 PM
seabass1858
1983 CJ7
or a gauge when you set valves. either or. Im working on a non stepper bbd off of a j20 as we speak. the guy bought a new bbd and gave me the old one as payment for helping him set the new one up
seabass1858 is offline
post #36 of 151 Old 02-24-2014, 09:32 PM Thread Starter
moto450r
Use a wire spark plug gap gauge, to set that gap. LG
Hey were you peeking?
moto450r is offline
post #37 of 151 Old 02-24-2014, 10:30 PM Thread Starter
moto450r
ordered some new jets from this place
http://www.carburetor-parts.com/
moto450r is offline
post #38 of 151 Old 02-25-2014, 03:29 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I have a couple of BBD's with mismatched jets also. I wonder why?
I seen both sets of needles mentioned and even different springs used in the piston.
You can see how mixing and matching parts would make for some interesting A/F ratios.
John Strenk is offline
post #39 of 151 Old 02-25-2014, 05:38 AM
Mike Romain
For some reason each barrel of the carb 'appears' to feed 3 cylinders according to the spark signal I see with a timing light when I am dealing with one plugged idle tube. It seems the inboard barrel appears to feed cylinders 1-3 and the outboard seems to feed 4-6. I have noticed on some that plugs 1-3 show slightly richer than 4-6. Maybe AMC was trying to balance this on some models?
Just a wild guess.
Mike
Mike Romain is offline
post #40 of 151 Old 02-25-2014, 05:47 AM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by Mike Romain
For some reason each barrel of the carb 'appears' to feed 3 cylinders according to the spark signal I see with a timing light when I am dealing with one plugged idle tube. It seems the inboard barrel appears to feed cylinders 1-3 and the outboard seems to feed 4-6. I have noticed on some that plugs 1-3 show slightly richer than 4-6. Maybe AMC was trying to balance this on some models? Just a wild guess.
That's highly possible. On my motorcycles the inner carbs had leaner needles and main jets to account for the center cylinders running hotter than the outside
Would the rear cylinders on the 258 run hotter than the front or colder than the front? I guess a temp gauge in the t-stat housing and the one towards the back of the head would be a comparison..........
post #41 of 151 Old 02-25-2014, 07:22 AM
John Strenk
1976 CJ5
I would tend to think the inner cylinders run richer than the end cylinders.
But doesn't the carb just dump into a plenum?
post #42 of 151 Old 02-25-2014, 07:31 AM
Mike Romain
Well, the inboard port is closer to the engine in the opening so it likely has slightly more vacuum maybe? If they were side by side, then it should draw even, but not that way.
When folks blow headgaskets and/or have ring issues, it is usually at the cylinder 6 or 5 area. That is where my old engine lost all its compression. 5 was dead.
Mike
post #43 of 151 Old 02-25-2014, 10:12 AM Thread Starter
moto450r
The carb is supplying the fuel air mixture to the manifold and there are no secondary's so the only thing I can come up with is that the "Outboard" (looking forward from the drivers seat) "barrel" has the vacuum port blocked. Where the inboard barrel has a vacuum port open for use. Maybe there is a fuel/air mixture difference because of the way the carb barrels provide, or don't provide a vacuum source?
moto450r is offline
post #44 of 151 Old 02-25-2014, 10:15 AM Thread Starter
moto450r
Got the carb back on this morning. Starting the tuning phase.
moto450r is offline
post #45 of 151 Old 02-25-2014, 10:37 AM
86cj74.2L
86cj74.2L's Avatar
The blocked vacuum port on the outboard barrel is the emissions port which jeep doesn't use. They chose to use the ported ignition vacuum instead via the CTO.
