Carter BBD Question! - JeepForum.com
post #1 of 6 Old 10-29-2002, 07:20 PM Thread Starter
CJ7Danny
Ok folks.... other than throwing this thing in the trash for a fix, I need some input!
Just rebuilt this thing and it runs worse than before! It idles fine but when I attempt to give it more than a quarter throttle under load, it falls on it's face.
What the hell? Anyone have any suggestions?
Dano
85 CJ7 Laredo Hard Top
33" BFG M/T
T176
Moser One Piece Axles
D300, D30, AMC 20, 258 ci
Motorcraft 2100 swap
Nutter By-Pass
Custom front bumpers
Custom Rear bumper/tire carrier
CJ7Danny is offline
post #2 of 6 Old 10-29-2002, 07:57 PM
55-willys
not sure if your carter is like the edelbrock, but id say that your fuel level is to low. a edelbrock will do that, and it doesnt take much to cause it. maybe only a 1/16 or so on the float adjustment, so try raising your float level a little at a time. you my have to do this a couple of times to get it right.
paul
55-willys is offline
post #3 of 6 Old 10-29-2002, 09:12 PM Thread Starter
CJ7Danny
thanks for the suggestion Paul. I had a feeling it was a float level issue. It's really the only thing that I adjusted during the rebuild. Of course, I adjusted to the OEM specs. Apparently, that isn't what I need!
I really just need to get this thing running well enough to get it a friends house so I can swap it out for a MC 2100 carb.
Dano
33" BFG M/T
T176
Nutter By-Pass
CJ7Danny is offline
post #4 of 6 Old 10-30-2002, 01:00 AM
johny1i
johny1i's Avatar
When you take the lid off the top (it's held on by 3 flat-blade screws) there are two arms inside that pivot around an axis and they have screw adjusters on them to dictate when the accelerator pump engages. It is ABSOLUTELY CRUCIAL that those are adjusted properly or you will have a terrible flat spot, as you noted. It took me many trial runs down the road with that little lid off and making periodic adjustments to get it just right. I mentioned this in your other thread, but you really need a manual, like Chilton's, to be able to adjust it properly because it shows some pictures. They're only about $13, but well worth that if you do your own work.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #5 of 6 Old 10-31-2002, 08:01 PM
Jeep Daddy
Jeep Daddy's Avatar
When you are done with that carb, I could use one for spare parts. I'll send you money for the freight.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #6 of 6 Old 11-03-2002, 05:42 PM
1986CJ7Andy
Carter BBD
I dont know what vehicle you have but I had a Carter carb and well didnt have much luck. Depending on what you wanna deal with. I actually had given up and replaced it with a Autozone or Advance carb, dumb idea. made things worse...
Well anyway I went out anf bought a weber carb from 4wd.com, I tell you what it made a huge difference!!! The big thing is that it eliminates the emissions so if your state requires it sorry but you might be out of luck. If you can try it, I actually use less gas and better performance.
1986CJ7Andy is offline
question about carter BBD m_t_r_86 Jeep CJ Forum 12 04-19-2011 12:02 PM
Another Carter question/HELP jdmartie Jeep CJ Forum 18 01-16-2010 10:04 AM
Carter BBD question diver49 Jeep CJ Forum 4 10-07-2008 08:50 PM
Carter BBD question jrylb73 Jeep CJ Forum 4 04-12-2007 05:17 PM
another carter question derm Jeep CJ Forum 2 10-03-2002 05:32 PM
