Carter BBD Help - JeepForum.com
post #1 of 20 Old 10-11-2008, 06:38 PM Thread Starter
doeboy99
Carter BBD Help
Ok just installed a remaned carter BBD in my project 79 cj5 amc 258.
I can not get it to start or run unless I hold the choke open. Also I get a bogging and back firing under fast exceleration*. I took some pics and labeled where I have all of the vacuum lines running. Please any help would be great.
It has 1,453,580 miles on 5 engines. Its been in 132 of the worlds 195 countries. VEX will be missed.
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #2 of 20 Old 10-11-2008, 06:54 PM
ScotZ
American to the Bone
ScotZ's Avatar
I have to ask. Why did you go with the Carter? The tubes are probably clogged. I went with the MC2100 and never looked back.
By the way. Nice looking job on the install!
http://www.cjoffroad.com/writeup.asp?WU_ID=16&noAdd=1
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #3 of 20 Old 10-11-2008, 06:58 PM Thread Starter
doeboy99
Why carter? Price mostly. What tubes could be clogged everything is brand new and carb was just rebuilt and cleaned?
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #4 of 20 Old 10-11-2008, 07:02 PM
ScotZ
ScotZ's Avatar
No worries. I kept mine going for years before I changed. This might help.
I was talking about the idler tubes in the venturie(sp?)
http://www.planethoustonamx.com/main...r_carb_fix.htm
- Aldous Huxley
ScotZ is offline
post #5 of 20 Old 10-11-2008, 07:04 PM
ScotZ
ScotZ's Avatar
If I recall I had to drill the tubes out to .032 or something close to that. It worked like a champ after that
- Aldous Huxley
ScotZ is offline
post #6 of 20 Old 10-11-2008, 07:14 PM Thread Starter
doeboy99
Thanks for the help I am going to take a look at those tubes but that link said it solves hard idling. Mine idles fine it just back fires and boogs when i get on the gas real hard.
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #7 of 20 Old 10-11-2008, 07:22 PM
ScotZ
ScotZ's Avatar
Are you sure its not a timing issue?
- Aldous Huxley
ScotZ is offline
post #8 of 20 Old 10-11-2008, 07:43 PM Thread Starter
doeboy99
Pretty sure 8 BTDC if I remember corectly.
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #9 of 20 Old 10-12-2008, 06:21 AM Thread Starter
doeboy99
anyone else have any ideas?
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #10 of 20 Old 10-12-2008, 06:44 AM
kjhibbs
1981 CJ8
First of all you should put a plug over that nothing nipple. It should be ported vacuum and will suck more air as you accelerate. Secondly I would richen your choke several notches and try pulling the spring that you attached to it. Does the engine accelerate okay after it warms up to normal operating temp?
1981 Scrambler; Vortec 4.3 / 4l60e swap; 35s; getting close!
kjhibbs is offline
post #11 of 20 Old 10-12-2008, 07:14 AM Thread Starter
doeboy99
Yea I already pluged the one nipple. Seeing as how I am not familer with carbs what so ever how would I richen the choke? And no it still runs like crap even after warmed up. I got on it pretty hard with the throttle arm and it backfired so bad it shot my air filter off.
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #12 of 20 Old 10-12-2008, 10:25 AM
Mike Romain
Your plumbing is pretty messed up from what I can see. This can cause your issues.
Let's start off with photo 1.
The two top vents must be open and put togeter in a T fitting like it was, you cannot have the float bowl vent blocked or it will bog. This line then goes to the charcoal canister on the 'carb' nipple or the one closest to the engine or farthest from the valve on the canister's top. The next line on the canister goes to the gas tank vent.
Then get rid of that spring on the choke and see below.
Next the gas filter is in upside down. The center line goes the the carb and the top line goes to the return line. Yours has the return lower which allows gas to siphon back to the tank when it sits.
Then below the spring, on the valve cover side of the carb is a vacuum nipple. This one goes to the distributor. The one you have marked to the distributor now gets capped, it used to run the stock air filter TAC system.
Now photo 2:
The line running to the canister on the bottom corner is right and should go through a CTO valve so the canister only turns on when the engine warms up.
Cap that distributor line nipple on the back corner and cap that open one up top.
Photo 3:
The line to the PCV valve needs a T fitting. From this T fitting, the other line runs to the canister purge or the line right under the round valve thing that gets the little vacuum line.
Photo 4:
OK I see the heat tube for the choke there so that is at least hooked up. The adjustment notch on the choke cover is int he wrong place, it should be two notches on the other side of 0. I think you need to open this black cover and make sure the choke linkage grabbed the spring inside. It is easy to get it wrong or have it fall off when putting the cover back on.
The choke is supposed to be closed after you give the gas pedal a shot of gas before starting the engine and as the engine warms up it opens. You need to remove the air filter and verify this is happening and get back to us.
Once you have the choke working, you warm up the engine and put the fast idle cam on the second from top step and set the screw so the rpm is 1700-1800 rpm. This sets up the choke's fast idle for start up.
To start this engine, you must pump the gas at least once, usually twice before turning the key. This primes the carb and sets the choke on. In real cold weather, more pumps are needed.
Mike
Mike Romain is offline
post #13 of 20 Old 10-12-2008, 10:53 AM Thread Starter
doeboy99
Thanks Mike Ill work on all of that and get back to you.
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #14 of 20 Old 10-12-2008, 12:28 PM Thread Starter
doeboy99
Ok mike I made all the adjustments with all of the t's that were needed now I am running really rich with a backfire when I shut the motor down. What now?
1989 YJ - Sold
2000 TJ
1979 CJ5 - Sold
1979 CJ7 - Sold
doeboy99 is offline
post #15 of 20 Old 10-12-2008, 01:23 PM
Mike Romain
Now you need to set the best lean idle mix up.
To do this, you screw the two bottom front screw and spring sets in all the way counting the turns usually to see what it was at. Then you back them out 5 turns each and get it running.
You will want to keep the idle below 700, preferably 650 so you may have to adjust the idle speed screw while you do the next part a couple times.
You turn the mix screws in 1/4 turn each and give it a rev of gas, then another 1/4 turn each and another rev and continue until one of the turns starts the engine rumbling. It will be obvious. When this happens, you back the screws out 1/4 turn to have your best lean idle mix. When I set them for the sniffer, I only back off 1/8 turn and leave a slight rumble. It seems to like it there.
Then you may want to check the timing and make sure it's about 8 deg or until it is the smoothest at idle before setting the mix. You do this with the distributor line off and plugged.
Sometimes if I change the timing I then screw the idle mix screws in again, just to be sure it hasn't changed when I changed the timing.
Mike
hei and carter ? damian H Jeep CJ Forum 1 11-03-2006 07:06 AM
Carter YF countrybob Jeep CJ Forum 1 09-27-2005 02:20 PM
Carter 1 bbl YF jamesa Jeep CJ Forum 4 10-13-2004 11:22 PM
Carter BBD OKJeepin Jeep CJ Forum 4 04-16-2004 07:45 PM
Carter VS. Mc Smalls Jeep CJ Forum 1 04-09-2003 08:46 PM
