Carter BBD - JeepForum.com
post #1 of 5 Old 04-14-2004, 08:24 PM Thread Starter
OKJeepin
OKJeepin's Avatar
Carter BBD
I just put in an 83 258 in my Jeep, and have had no dealings with the infamous BBD till now.
It won't idle, unless I choke it almost closed, then it purrs like a kitten.
Engine was at normal operating temp, I byapassed the stepper motor (cut off the needles where they taper down), as I have no 'puter in my 1974, and there appears to be no vacuum leaks.
Any ideas?
Jeff
1974 CJ-5 (Rockcrawler)
2001 Grand Cherokee Laredo (Curbcrawler)
OKJeepin is offline
post #2 of 5 Old 04-14-2004, 08:53 PM
jeepsarecool
jeepsarecool's Avatar
1982 CJ7
Any ideas?
Jeff
You may have seen this before, and since it runs with the choke closed, I don't know if it will help, but check this out:
http://www.jeeptech.com/engine/carter.html
Check out my
CJ7 - God's gift to the masochist.
jeepsarecool is offline
post #3 of 5 Old 04-14-2004, 09:01 PM Thread Starter
OKJeepin
OKJeepin's Avatar
Good article, I'll check it tomorrow and see if thats the problem. Thanks
Jeff
OKJeepin is offline
post #4 of 5 Old 04-14-2004, 09:06 PM
Orange Juice
Having to run with the choke nearly closed is a sign of fuel starvation. This typically happens because of a couple of factors. First, your idle mixture is either too rich or too lean. Secondly, your idle circuit of the carb is varnished causing a restriction in fuel flow thru the idle circuit. The idle circuit is basically the only part of the carb that continues to flow fuel no matter what the rpm range is. In other words, the idle circuit operates any time the engine is running. Because of this, it will affect the engine no matter what rpm you are running. You have to get the idle straightened out on a carb before you can even start tuning anything else.
Orange Juice is offline
post #5 of 5 Old 04-16-2004, 07:45 PM Thread Starter
OKJeepin
OKJeepin's Avatar
"jeepsarecool" you hit it on the head, I pulled the carb apart, pulled out the venturi section, one of the tubes going down into the bottom of the carb was plugged up solid, cleaned it out and presto, smooth idle!
Thanks again
Jeff
OKJeepin is offline
Carter BBD Help doeboy99 Jeep CJ Forum 19 10-12-2008 03:13 PM
hei and carter ? damian H Jeep CJ Forum 1 11-03-2006 07:06 AM
Carter YF countrybob Jeep CJ Forum 1 09-27-2005 02:20 PM
Carter 1 bbl YF jamesa Jeep CJ Forum 4 10-13-2004 11:22 PM
Carter VS. Mc Smalls Jeep CJ Forum 1 04-09-2003 08:46 PM
