carrying ridiculous amounts of water - JeepForum.com
post #1 of 15 Old 10-18-2011, 10:16 PM Thread Starter
billybooster2
1983 CJ8
in the interests of wastng time on a tuesday night, has anyone added, to a cj8, an under body, rear water tank (or tubes linked in series) rearward of the gas tank in order to carry copious amounts of water in a hostile (read desert) environment? I was thinking of linking, say 4 x 4" diameter, 2-3ft long pipes at the back. Add a pump or a gravity feed tap and voila... water on tap! thoughts?
PS (im bored of pretending id ever figure out a 4.3 TBI junkyard swap so i came up with white pipe and blue glue )
id olike to see an install if anyone has one?
billybooster2 is offline
post #2 of 15 Old 10-18-2011, 10:24 PM
benullman
1981 CJ7
we carry 80 gallons in a tank in our brush jeep at the fire house.
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #3 of 15 Old 10-18-2011, 10:25 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i would imagine that it would weigh more than its worth. for the rare occasion that you would need it, just carry extra jugs
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #4 of 15 Old 10-18-2011, 10:27 PM Thread Starter
billybooster2
1983 CJ8
ben, the ryans, thankyou for confirming that someone does! I was hoping for a picture, diagram , parts list, weight, dimensions.... actualy i wasnt! I just thought itd be cool to offer the ladies a wash room thus enticing further their presence!
I know its heavy, but it could work if really needed to stay a week or more 'out there', no?
post #5 of 15 Old 10-18-2011, 10:36 PM
benullman
1981 CJ7
we are about to restore the CJ7 this year. I can take picutres this week. we are looking at running an engine driven pump. We will also use a 90-100 gallon poly tank to save weight. Along with an aluminum hose reel and 150-200 feet of 3/4" line. It will be setup with a 2.5" fintake in the front bumper and rear end. there will also be a 1-3/4" disharge on the front and rear if we needed to pump straight to the Jeep, using it as a manifold/booster pump and push a larger line.
There will be a build thread when it starts.
Ben
post #6 of 15 Old 10-18-2011, 10:39 PM
lucdog
1980 CJ5
OP how many gallons would you need for a week?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 15 Old 10-18-2011, 10:45 PM
benullman
1981 CJ7
Bill
hey Bill, does your company run a brush rig? If so how many gallons and how is it setup?
Ben
post #8 of 15 Old 10-18-2011, 11:09 PM
lucdog
1980 CJ5
We don't have any brush equipment. Its all city stuff, 5 of our 13 engines each carry 400' of 1" single jacket. We add that to 200' of 1" reel line. The same 5 have 2 back pack's that hold 5 gallons. The VFD dept's use either a JD Gator, or a 4x4 pickup.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #9 of 15 Old 10-18-2011, 11:11 PM
lucdog
1980 CJ5
Bill
1' of 4" PVC holds 0.6528 gallons. 5" is a gallon per foot.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 15 Old 10-19-2011, 09:56 AM
cjdogtoy
1976 CJ5
I live in what you might call a hostel environment, around hear in the summer a trip in the desert can include 120 degrees, and a trip through stop and go on four lanes of black top gets hotter than that. I use a 5 gallon gas can for engine water and just bring 1 gallon jugs for drinking water. you don't want to drink water that has bean stored on the jeep for extended periods of time as it goes stagnant, and flushing and cleaning your containers is more trouble than it's worth, it's easer to stop at the gas and gulp and buy pure water for $1.00 per gallon when your headed out. As to how much to carry, desert survival says 3 gallons per day per person, you would be amazed at how much and how fast that dry hot air can pull out of you. I also do out door work and go threw this on a daily bases, I tend to drink 4 gallons of water and 2 32oz. Gatorade's. hope that helps.
cjdogtoy is offline
post #11 of 15 Old 10-19-2011, 10:46 AM
Pathkiller
1974 CJ5
Read about how Mike Boyink installed a freshwater tank in his CJ6 here: http://boyink.com/cj6/onboard-fresh-water-system/
Granted, it's a lot smaller tank than you're talking about, but the basics are the same. You could mount a much larger tank in a CJ8 in the area behind the gas tank, probably at least 10-15gal if you were creative about it. I would probably only consider doing this if I was camping for extended periods in the Jeep with only a tent. Jeeps dont' have an abundance of space for storage of water cans, so something like this could free up some storage space for other supplies.
Pathkiller is offline
post #12 of 15 Old 10-19-2011, 11:04 AM
Destr0
I would use a plastic tank - the weight of steel tubing vs. the amount of water you can carry in steel tubes just isn't worth the fab time and weight.
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #13 of 15 Old 10-20-2011, 05:37 PM
GPER
1979 CJ7
There is a bladder that fits in the bed of pick ups to add weight that is filled with water. I don't remember the name but shouldn't be to hard to find. They had them to fit in car trunks too.
GPER is offline
post #14 of 15 Old 10-20-2011, 05:42 PM
chromegrille
1947 CJ2A
thumbs down on those.....mine busted after two uses
plus there is no room for anything else wherever the bladder lies
nothing can rub or poke up against it
waste of money for mobile applications
BTDT.....never got the shirt
chromegrille is offline
post #15 of 15 Old 10-20-2011, 06:58 PM
ButcherJones
ButcherJones's Avatar
1977 CJ5
I just spent the last ten years in Phoenix...I agree!
Storing a water tank worth of water under my jeep seems to be a little on the overkill side...
ButcherJones is offline
Wow,the new king of CL ridiculous,55K CJ!! Lordwrench Jeep CJ Forum 51 02-16-2011 01:03 PM
To fix or not to fix? Water pump or water pump, steering box leak and heater core? brussell Jeep CJ Forum 3 04-18-2010 12:03 PM
Water in the oil CopenhageCowboy Jeep CJ Forum 17 12-30-2009 01:11 PM
f-134 water in oil Rumpeltiltskin Jeep CJ Forum 7 12-13-2009 09:08 PM
Water from what ?? brc75654 Jeep CJ Forum 8 11-28-2006 04:02 PM
