Which is the carrier culprit ?? AMC 20 - JeepForum.com
post #1 of 9 Old 11-12-2013, 02:03 PM Thread Starter
stvincnt
1979 CJ5
I have a bit of slop in my spider gears. What is the most common places for wear, Carrier pin, carrier pin holes on carrier or roll pin. My big concern is the carrier holes are the culprit but shouldn't there be a little bit of play in there to slip the pin in ?? Otherwise the spider gears look clean, so does the ring and pinion
stvincnt is offline
post #2 of 9 Old 11-12-2013, 04:21 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The pin should be a slip fit with no movement in the carrier. Movement can cause the retaining pin to shear, allowing the shaft to slide out. If the slop is bad enough, it can also crack the carrier. A slight movement can be monitored, but if you have definite clearance between the pin and carrier, then the carrier should be replaced.
"Slop" in the spider gears is common and will not hurt anything as long as there is no damage to the teeth and the thrust washers are serviceable.
jeepdaddy2000 is offline
post #3 of 9 Old 11-13-2013, 09:04 AM Thread Starter
stvincnt
1979 CJ5
Thanks for the reply, I'm gonna see if that roll pin is worn, looks fairly easy to punch through.
stvincnt is offline
post #4 of 9 Old 11-13-2013, 11:16 AM
jeepwhore
I highly doubt the retaining roll pin would cause what you are seeing. I'd bet it's the cross shaft itself. I had one worn so badly where the spiders rode that I couldn't get my Aussie locker set up within spec. Hopefully you have 2.73 or 3.31 gears so you can remove the shaft without having to pull the carrier out and remove the ring gear to inspect it (Not sure if the shaft will clear 3.55 or 3.73 gears).
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #5 of 9 Old 11-13-2013, 01:41 PM Thread Starter
stvincnt
1979 CJ5
I have 3.55's and it looks like that shaft will slip through the carrier no problem, I am able to get to the roll pin from the left of the carrier(punch it through)
stvincnt is offline
post #6 of 9 Old 11-13-2013, 01:57 PM
jeepwhore
Should be able to inspect it without issue then. The wear will be pretty apparent if it's there.
post #7 of 9 Old 11-13-2013, 03:51 PM
jeepdaddy2000
1971 CJ5
The word "pin" should be "shaft" instead.
Same thing here.
Good catch guys.....
post #8 of 9 Old 11-14-2013, 09:18 AM Thread Starter
stvincnt
1979 CJ5
Worn carrier shaft and bent roll pin
[QUOTE=jeepdaddy2000;17680441]The word "pin" should be "shaft" instead.
I suppose this is what a well worn carrier shaft looks like and bent roll pin
stvincnt is offline
post #9 of 9 Old 11-14-2013, 03:42 PM
jeepdaddy2000
1971 CJ5
Yup.
Funny, I just replied to that thread.....
