Carburetor problem - JeepForum.com
post #1 of 4 Old 04-16-2013, 08:35 AM Thread Starter
dubya5813
1979 CJ5
Carburetor problem
Since I'm finally at work, I'll have to sit and stew about this all day until I can get home and check. So I'll take all of the opinions I can get....
Decided to bring the jeep to work today, it'd been a week or so since I last drove the jeep and it's a beautiful day......jeep started up a little sluggish, but warmed up and idled fine. I get to the first stop light, put it in neutral immediately tries to stall. I notice this same pattern, every time I take the load off the motor, it tries to stall or in 3 instances does stall. It ran fine and as long as I kept it in gear continued to do so. AS SOON as I put it in neutral or took the load off the motor, without a little revving, the motor would quit. Now, If I got to a complete stop (no idea if this has any bearing) it'd eventually idle OK. So, I obviously (I think anyway) have carburetor or fuel line issues.....won't be able to check until I get home tonight, so feel free to discuss
dubya5813 is offline
post #2 of 4 Old 04-16-2013, 10:26 AM
86cj74.2L
86cj74.2L's Avatar
I'm on my cell and can't see profile. Post what you got.
86cj74.2L is offline
post #3 of 4 Old 04-16-2013, 11:25 AM Thread Starter
dubya5813
1979 CJ5
SBC 350, 4 barrel holley 500.....was running just fine last time I had it out, about a week ago. I'm thinking stuck float or vacuum leak somewhere. Stuck float doesn't make sense to me though since throttle response is fine, only wants to stall when load is removed, if I feather the gas, it'll settle into a low idle, lower than I had it set.....
post #4 of 4 Old 04-16-2013, 11:26 AM
86cj74.2L
86cj74.2L's Avatar
A vacuum leak sealed up.
