Carburetor adjustment??? - JeepForum.com
post #1 of 20 Old 06-27-2013, 11:36 AM Thread Starter
Chlarock
I have a CJ7 258 with Carter BBD ( I just rebuilt), no stepper on it and a Nutter Bypass, no smog/air cleaning crap, no computer and a regular distributer with ignition coil. Pretty strait forward setup. All seems well except when you hit the gas hard/quick it sounds like it's starved for air and will stall. A slow press of the pedal and she revs up find. I know this is a bunt for some of you guys but I'm not an expert. Also...can anyone tell me what vac holes to plug and what needs to be open. I need air from someplace but I don't know where. The choke seems to be open but I don't know if it's open enough...maybe it's at about 45 degree angle. Some help PLEASE. Thanks.
Chlarock is offline
post #2 of 20 Old 06-27-2013, 12:14 PM
firemanjim7
1983 CJ7
Sounds like a fuel pressure issue. I'd start off by changing the fuel filter(make sure it's the right one and connected correctly). If that doesn't help check fuel pump. The float height might not be set properly too in the carb since the rebuild.
firemanjim7 is offline
post #3 of 20 Old 06-27-2013, 12:37 PM Thread Starter
Chlarock
Pump and filter are fairly new but had old gas in tank so filter could be it. About the float height though...too high or too low??? What do ya think? Thanks for the quick response also.
Chlarock is offline
post #4 of 20 Old 06-27-2013, 01:25 PM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Chlarock,
I would double check the accelerator pump spec and the possibility that one of the check balls (is it legal to say check balls?) was omitted or the little one was put in where the big one should be. Can you get a good steady stream of fuel into the venturi as you move the the throttle plate linkage?
Also, timing advance plays a part in the "snap" when you hammer the skinny pedal. Is timing in the 8* to 12* area? There are some good threads about timing, tuning and how they all work together. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #5 of 20 Old 06-27-2013, 02:17 PM Thread Starter
Chlarock
You lost me a bit there Jon In Tucson. My balls are good (is THAT legal???). But what do you mean buy the accelerator pump spec? How Do I check that. Timing is at 8*ish. Also, what about all the vac line connections on the carb. What gets capped and what do you need connected? I'm mainly confused about the two large ones at the top that are one above the other opposite the throttle linkage side.
Chlarock is offline
post #6 of 20 Old 06-27-2013, 08:16 PM
Jon In Tucson
1983 CJ5
I guess what I was trying to say that there is a little cam and "s" link that operate the accel pump lever. I don't remember how it is supposed to be set. God bless.
Jon In Tucson
panic." - Mike
post #7 of 20 Old 06-27-2013, 08:51 PM Thread Starter
Chlarock
Thanks for the help. It's another adjustment I wasn't aware of. I'll do some research. Thanks again.
Chlarock is offline
post #8 of 20 Old 06-27-2013, 09:18 PM
pman
The accelerator pump adjustment is a little different on the Carter (versus, say, the MC2100/2150). The adjustment is made inside the carb under the top cover.
Do you have a good TSM? It will be infinitely helpful when dialing in your carb. All the specs are there.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #9 of 20 Old 06-27-2013, 11:00 PM
LumpyGrits
Recheck your float level to be sure the res. for the acc. pump is filled to the notches.
LG
LumpyGrits is offline
post #10 of 20 Old 06-28-2013, 12:43 AM
BagusJeep
1981 CJ7
You need to get the Carter BBD rebuid manual, you can find it on line.
There is a procedure for setting the float level, accelerator pump and metering rods relative to the throttle linkage that is a bit fiddly but amy be the cause of some of your problems.
The choke only opening 45 degrees suggests an issue with the choke setup. Again you need to consult the manual.
The accelerator pump may not be delivering. Mine fell apart an dlack of pump was the final straw that made me buy a Weber 38 aftyer 5 years of struggling with BBD.
The other problem may be leaks. If you do not have the correct vacuum tube setup and have an open one you will struggle to have the right mixture at all stages of throttle position.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #11 of 20 Old 06-28-2013, 05:00 AM
86cj74.2L
86cj74.2L's Avatar
If your choke plate isn't strait up and down after warm up it needs fixed.
Watch this:
86cj74.2L is offline
post #12 of 20 Old 06-28-2013, 10:33 AM
texas1al
I agree with the comments about the choke plate, doesn't sound like it's open completely. Also agree that you should confirm all vac ports are plumbed correctly or capped if not being used. Couple other things to think about - I've heard the EGR can cause hesitation coming off idle. Not sure if you have an EGR valve since you said the engine has no smog equipment, but if you do, you can try unhooking the vacuum line at the EGR and plugging the line. Another thing for me was the idle mixture screw adjustment. I had a bad hesitation on my Carter coming off idle and I was able to eliminate it by fiddling with the idle mixture screws. I think I had to richen the idle mixture. Not sure why that helped, but it definitely eliminated the stumble in the transition out of the idle circuit in the carb.
texas1al is offline
post #13 of 20 Old 06-28-2013, 01:48 PM Thread Starter
Chlarock
Excellent info from ALL.
Hey I got a joke
Guy walks into a bar and says "I just rebuilt my carb". Bartender says "must run great". First guy says " It would but I put the Venturi Cluster in UP SIDE DOWN"!!!
What a DOPE!!!
Guess who the guy is that walked into the bar????
Jeep runs like a top now. Cluster blocks the choke from opening all the way when it's FREAKIN' UP SIDE DOWN!!!!!
Sorry to waist all your time but THANKS A MILLION for the help. I did learn a bit more about carbs though.
Chlarock is offline
post #14 of 20 Old 06-28-2013, 04:25 PM
Oily
There is a sock filter inside the tank on the fuel pick up tube. Mine was restricted badly. See if you can blow thru the lines backwards into the fuel tank.
Oily is offline
post #15 of 20 Old 06-28-2013, 06:58 PM Thread Starter
Chlarock
I put a new fuel sender in the tank.
I thought I was out of the woods and went for a test drive. If I take my foot of the gas quickly at say 40 or 50 MPH to shift, the engine dies. What adjustment would that be??? Or is it a timing issue? I set the timing at about 8*<
Chlarock is offline
