Which Carburetor? - JeepForum.com
post #1 of 10 Old 07-12-2009, 09:11 PM Thread Starter
jamest1234
Which Carburetor?
I have a 1986 stock CJ7 that I'm replacing the carburetor on. Does anyone know if I should be ordering a carburetor with a stepper motor or one without the computer hook up. This site has two listed.
http://www.guaranteedcarbs.com/cgi-b...6&keywords=all
Thanks!
jamest1234 is offline
post #2 of 10 Old 07-12-2009, 11:18 PM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
James,
If your '86 is stock and has the wire plug stuck into the back of the carb, then you need the stepper motor/ feed back carb. If you have doubts, call those folks up at the carb place with the tag number. It is the little metal thing on the top of the carb with one of the screws through it. That will assure you that you get the right one for your application. Is the carb too worn out to rebuild? The kits for a BBD is around $20.00 and it is not too difficult a chore. The best thing to do if you decide to rebuild your own carb is not to get in a hurry. Mike Romain, who posts here quite often is a Carter BBD guru, and is great for advice. Good luck and God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #3 of 10 Old 07-13-2009, 04:05 AM
Bubba Ray
Do you have emissions testing? If not then you may want to consider the Nutter bypass(do a search). This will free up your carb choices and make your Jeep run better. Look into the team rush ignition upgrade too.
Bubba Ray is offline
post #4 of 10 Old 07-13-2009, 04:09 PM
SD84CJ7
What if you do have emissions to worry about?
SD84CJ7 is offline
post #5 of 10 Old 07-14-2009, 09:38 AM Thread Starter
jamest1234
Thanks for the feedback. This helps a lot. I've rebuilt this carburetor a number of times but think it is better to go with a remanufactured one. If I didn't still have emissions to worry about I would go with one of the other options. But give that VA is one of those testing states, that path isn't open as far as I can tell.
Cheers!
post #6 of 10 Old 07-14-2009, 01:03 PM
strongarm
Go with the Weber 32/36. Straightforward installation and you will regret not having done the swap sooner.
strongarm is offline
post #7 of 10 Old 07-14-2009, 05:55 PM Thread Starter
jamest1234
Would this impact the emissions testing. I think I still have another year or two where I still need to have emissions done in VA.
post #8 of 10 Old 09-08-2009, 12:47 PM
uncasid
I have the same jeep and am also looking to do an upgrade. Does the 32/36 impact the emissions testing?
uncasid is offline
post #9 of 10 Old 09-08-2009, 03:35 PM
chill254
1984 CJ8
It really depends on your state and how particular they are about the visual inspection because you can probably pass the sniffer.
The weber is not a factory carb and is not desigined to incorperate the emission controls on the jeep.
In some states that will fail you.
The factory carb was part of a feedback system that includes the carb metering pins, o2 sensor, and timing adjustment.
I could get my jeep to pass the sniffer with an old EMPI I had. So if all you have to pass is the sniffer then you MIGHT be ok. Lots of thing can effect your emissions beyond the carb.
The best thing you can do is to check you laws and take another car and see how particular they are about the visual inspection.
Basic answer is yes going to anything other than a factory carb will impact emissions testing.
chill254 is offline
post #10 of 10 Old 09-08-2009, 05:12 PM
CJhollic
1980 CJ7
I have a Weber 32/36 and pass emissions with ALL of the pollution control junk by passed.
You may want to check local laws to see how picky they are on the visual. In ABQ all they care about is CO and NOX
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
304 carburetor jeepcj304 Jeep CJ Forum 7 01-13-2012 10:15 AM
Best Carburetor for AMC 360? Bobby9821 Jeep CJ Forum 8 08-15-2011 10:05 PM
Best Carburetor for 304??? Flange Jeep CJ Forum 5 03-19-2009 11:59 AM
Carburetor martin10 Jeep CJ Forum 11 06-05-2008 11:09 AM
Best Carburetor for this CJ-7 FLCJ7 Jeep CJ Forum 26 06-11-2005 03:17 AM
