Carb wires? - JeepForum.com
post #1 of 20 Old 10-18-2015, 01:20 PM Thread Starter
ImpulsiveGoat
Carb wires?
Can someone please help me identify what wires these are and what I need to hook them up to?
I just picked up my first CJ, so I'm learning as I go. First carbureted vehicle too so things look a little foreign to me. The yellow wire in the attachment below is the one in question. It connects to both sides of the carb then ran through the firewall but I have no idea what it should connect too. Thanks for the help guys
ImpulsiveGoat is offline
post #2 of 20 Old 10-18-2015, 02:32 PM
Renegade82
1982 CJ7
Looks like it may be previous owner mods. What kind of carb is it? What year is your Jeep? My carb in an 82 only has 2 wires, one for the choke and one for ground.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline
post #3 of 20 Old 10-18-2015, 03:30 PM
keith460
Jeep. There's Only One
keith460's Avatar
That looks to be a solenoid for a Weber 32/36 or a 38 DGV. Used to increase the rpm during low idle for either A/C or other means.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is online now
post #4 of 20 Old 10-18-2015, 03:33 PM Thread Starter
ImpulsiveGoat
Its an 85, not sure about any previous mods I bought it of a buddy and he bought it off of a shady offroad dealer. It runs good other than the vacuum leaks that seem to be everywhere. I was just going through all the wiring to make sure things are hooked up correctly but i'm stuck on this one.
post #5 of 20 Old 10-18-2015, 03:36 PM Thread Starter
ImpulsiveGoat
Does that mean I have a weber 32/36 or 38dgv? Sorry like I stated earlier im a bit of a rookie when it comes to the carb and CJ's in general but hey I'm trying. Also if I was to hook it up where would I do so?
post #6 of 20 Old 10-18-2015, 05:04 PM
cwig12
1983 CJ7
You more than likely have a 32/36 due to it having that solenoid there. One way to know for sure is the 38 has two synchronized gears that the linkage connects to which I don't believe the 32/36 has.
Creative-X 3D Printing and Design
Place orders through: creativex3dprinting@gmail.com
cwig12 is offline
post #7 of 20 Old 10-18-2015, 05:53 PM
keith460
keith460's Avatar
Without seeing the entire carb, I'm only guessing it is a Weber 32/36.
The yellow wire is going to the solenoid type valve. The other red wires are all choke wires but since it may have a non OEM carb, only one wire will be needed to control the choke.
1984 CJ-7 Renegade
post #8 of 20 Old 10-18-2015, 05:58 PM Thread Starter
ImpulsiveGoat
Here's where the yellow wire goes after the first picture, I'll get a picture of the whole thing posted tomorrow.
post #9 of 20 Old 10-18-2015, 06:28 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Need to ID the carb, first, then we can help more.
Matt
Matt1981CJ7 is offline
post #10 of 20 Old 10-18-2015, 08:06 PM
pedal2themetai
1956 CJ5
Sometimes close up pictures are just as good as no picture.. need to see detail .. back up a little..
pedal2themetai is offline
post #11 of 20 Old 10-18-2015, 08:33 PM Thread Starter
ImpulsiveGoat
will do ill get some better pictures up tomorrow.
post #12 of 20 Old 10-18-2015, 10:23 PM
Renegade82
1982 CJ7
That's not a Weber 32/36 unless it's of an old design. Mine looks nothing like that.
post #13 of 20 Old 10-19-2015, 04:05 AM
cwig12
1983 CJ7
When you take the new pics, be sure to pull the filter and take them so we can see the whole thing.
Edit: I pulled up some pics of a motorcraft carb and it looks similar but not sure with the current pics.
cwig12 is offline
post #14 of 20 Old 10-19-2015, 10:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Looks more like an idle cutoff so it will cut the gas flow to the idle circuit when the engine is turned off.
I had something like that on a couple of webers off a Fiat 128 and also on an old Solex carb.
For example:
http://www.4x4wire.com/forums/ubbthr...ric_choke.html
John Strenk is online now
post #15 of 20 Old 10-19-2015, 10:57 AM
keith460
keith460's Avatar
That makes sense John. I know Weber sells additional devices for their carb and the fuel cutoff solenoid was one of them.
1984 CJ-7 Renegade
